  • Replies 156
Specifications
Engine
Type: V12
Displacement cu in (cc): 365 (5988)
Power bhp (kW) at RPM: 660(485) / 7800
Torque lb-ft (Nm) at RPM: 484(657) / 5500
Redline at RPM: 8200
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 245/35 ZR19 - 345/35 ZR19
Exterior Dimensions & Weight
Length × Width × Height in: 185.1 × 80.1 × 45.2
Weight lb (kg): 2766 (1255)
Driveline: Rear Wheel Drive
Performance
Acceleration 0-62 mph s: 3.65
Top Speed mph (km/h): 225 (362)
Fuel Economy EPA city/highway mpg (l/100 km): n.a. (23)
i think the interior is really nice for such a cheap car
nothing is wrong with it....ive seen them go in very good condition for $5k with RWC and 12 months rego
My mate got one for his first car, he got it for 8k! and that was without reg + RWC, when he sees this he will be pretty pissed.
5k is cheap as. Maybe its that cheap because its red?
the only downside is that apparently their known for their engine and gearbox problems. I heard they are really rough, thats why they dont hold their re sale value. Its a pity, its one of those cars that look good but are really a lemon.
Edited by Paradizzle
Hey, i dont know why all these guys are giving you a hard time, ill let my car go for 3k. My parents are making me sell it, they say its too dangerous and i sorta got nowhere to live until i sell it. So yeah.
the car makes just over 500rkw on 2bar boost. Breaks traction in 5th gear on street tyres.
Tried to get it dyno'd at 4bar boost, but the car came off the dyno rollers, luckily we stopped it in time before it hit anything. So its got alot more potentional.
The engine is stock, the turbo has been changed tho. The engines are good for like 1500rwkw.
the car is in my pic
Mate stick to the Aussie cars, atleast you know where they're from and what they are like. Believe me, you can get a VS Commodore for around 7K, thats value for money. Forget about these highly modified cars for 3K. You'll have problems like engine failures, blown tires etc
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
