  • Replies 156
Specifications
Engine
Type: V12
Displacement cu in (cc): 365 (5988)
Power bhp (kW) at RPM: 660(485) / 7800
Torque lb-ft (Nm) at RPM: 484(657) / 5500
Redline at RPM: 8200
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 245/35 ZR19 - 345/35 ZR19
Exterior Dimensions & Weight
Length × Width × Height in: 185.1 × 80.1 × 45.2
Weight lb (kg): 2766 (1255)
Driveline: Rear Wheel Drive
Performance
Acceleration 0-62 mph s: 3.65
Top Speed mph (km/h): 225 (362)
Fuel Economy EPA city/highway mpg (l/100 km): n.a. (23)
i think the interior is really nice for such a cheap car
nothing is wrong with it....ive seen them go in very good condition for $5k with RWC and 12 months rego
My mate got one for his first car, he got it for 8k! and that was without reg + RWC, when he sees this he will be pretty pissed.
5k is cheap as. Maybe its that cheap because its red?
the only downside is that apparently their known for their engine and gearbox problems. I heard they are really rough, thats why they dont hold their re sale value. Its a pity, its one of those cars that look good but are really a lemon.
Edited by Paradizzle
Hey, i dont know why all these guys are giving you a hard time, ill let my car go for 3k. My parents are making me sell it, they say its too dangerous and i sorta got nowhere to live until i sell it. So yeah.
the car makes just over 500rkw on 2bar boost. Breaks traction in 5th gear on street tyres.
Tried to get it dyno'd at 4bar boost, but the car came off the dyno rollers, luckily we stopped it in time before it hit anything. So its got alot more potentional.
The engine is stock, the turbo has been changed tho. The engines are good for like 1500rwkw.
the car is in my pic
Mate stick to the Aussie cars, atleast you know where they're from and what they are like. Believe me, you can get a VS Commodore for around 7K, thats value for money. Forget about these highly modified cars for 3K. You'll have problems like engine failures, blown tires etc
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
