  • Replies 63
To be honest, I didn't notice a massive difference after the pineapples were fitted. There was a subtle difference but not massive on mine. I think that could have a lot to do to the fact I have fairly soft suspension. Best results with pineapples I think will be had with firmer (or the stock) suspension.
A soft ride has its benefits in everyday driving though, so I'm not too fussed.
I drove my friend's 200sx and fto etc... skyline suspension feels very spongy and has more body roll. I think its because the car is much more heavier than 200sx. But I am definitly less confident when doing some hard corner on normal streets with skyline.
maybe a aftermarket suspension will help?
any suggestions?
I drove my friend's 200sx and fto etc... skyline suspension feels very spongy and has more body roll. I am definitly less confident when doing some hard corner on normal streets with skyline.
I live in sydney and in some suburb the road condition are pretty bad. My car is about 2 inch lowered and I dont think the suspension isnt gonna have a long life if I travel alot on those bumpy roads.
considering handling and comfort. any suggestions?
Swaybars and as your car has been lowered an alignment kit. My car uses Whiteline bits and pieces, but there are other brands out there. Expect to pay about $700 for this.
Originally i ran around with King Springs, and after the alignment and swaybars noticed a big difference. Stayed that way for a few weeks then went back and got new shocks and matching springs. On the road there wasnt any real difference between the the whole hog (shocks, springs, swaybars, bushes, braces etc) and just the swaybars and alignment kit.
However a trip to the track highlighted the additional stability of the new shocks/springs.
the area I found that made the biggest diff was changing up to 2nd gear
before pineapples: tail slid out ... pretty dangerously in fact! So I was limited to the amount of throttle I could give it :D
after pineapples: chirps to 2nd, chirps to 3rd
I did change the tyres not long after putting the pineapples in, which made a huge diff too, however on the same tyres there was a definate gain in traction!
Personally I'd say the pineapples work best with a good set of tyres
Although on osc@r's silvia he said it reduced traction, even when set up the same way as mine ... however he has thinner tyres, so whether that's the diff or something else, I couldn't say
it seems to be of advantage to some cars but not others, perhaps the suspension you use too
but on my part, it's one of the best things that's helped traction for sure! and for 100 bux!
I have an R32 with stock suspension. To me the diff seems very tight, i don't know if it's normal or not, cuz i have nothing to compare with.
Anyhow, sometimes when i give my car stick around a corner, i get diff shutter (axle tramp??). Alot of people told me that was just because it was on the verge of not having enough power to fully slide out. But it seemed to happen whatever corner i tried to slide out of.
I haven't done it for awhile, due to the fuel factor.
Will pineapples help with this situation?
Yes they will help.
My cornering has been much more stable since installing the pineapples.
I have also noticed that wet weather driving is more consistant with the pineapples installed.
I have zero tyres on the back so of course that wouldn't help my situation! Still, I should be getting new 235mm tyres on some 17" rims on Friday, so that should improve handling on mine.
Improved sway bars (front and back) would definitely help. I had them on my old R31 and even though it had not much power, it handled pretty well for an old beast.
Guest nismogtsx
I am a 50/50 on pineapples....
My gf's 200sx has em and their ok, i drove it before an after and noticed that the rear felt tighter round corners... but it didnt feel natural and felt as though it might let go any second...
The pineapples reduced my confidence in taking corners hard...
Were they set up for all-round grip or straight-line grip? I've said it before in other pineapple threads and I'll say it again, all-round grip is the *only* way to set it up for a street car. Handling is comprised otherwise and I found it downright dangerous at times. Changing over from all-round to straight-line is a simple 30min exercise that you can do before a trip to the drags.
  • 1 month later...
$80 for installation is abit steep.
It should take a solid 30-40mins to install it and 25-30mins if they know what they are doing. (Surpisingly 2 suspension shops i went to had never seen them and no idea how to install them without the provided instructions).
Should probably cost you $170-180.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
