  • Replies 63
To be honest, I didn't notice a massive difference after the pineapples were fitted. There was a subtle difference but not massive on mine. I think that could have a lot to do to the fact I have fairly soft suspension. Best results with pineapples I think will be had with firmer (or the stock) suspension.
A soft ride has its benefits in everyday driving though, so I'm not too fussed.
I drove my friend's 200sx and fto etc... skyline suspension feels very spongy and has more body roll. I think its because the car is much more heavier than 200sx. But I am definitly less confident when doing some hard corner on normal streets with skyline.
maybe a aftermarket suspension will help?
any suggestions?
I drove my friend's 200sx and fto etc... skyline suspension feels very spongy and has more body roll. I am definitly less confident when doing some hard corner on normal streets with skyline.
I live in sydney and in some suburb the road condition are pretty bad. My car is about 2 inch lowered and I dont think the suspension isnt gonna have a long life if I travel alot on those bumpy roads.
considering handling and comfort. any suggestions?
Swaybars and as your car has been lowered an alignment kit. My car uses Whiteline bits and pieces, but there are other brands out there. Expect to pay about $700 for this.
Originally i ran around with King Springs, and after the alignment and swaybars noticed a big difference. Stayed that way for a few weeks then went back and got new shocks and matching springs. On the road there wasnt any real difference between the the whole hog (shocks, springs, swaybars, bushes, braces etc) and just the swaybars and alignment kit.
However a trip to the track highlighted the additional stability of the new shocks/springs.
the area I found that made the biggest diff was changing up to 2nd gear
before pineapples: tail slid out ... pretty dangerously in fact! So I was limited to the amount of throttle I could give it :D
after pineapples: chirps to 2nd, chirps to 3rd
I did change the tyres not long after putting the pineapples in, which made a huge diff too, however on the same tyres there was a definate gain in traction!
Personally I'd say the pineapples work best with a good set of tyres
Although on osc@r's silvia he said it reduced traction, even when set up the same way as mine ... however he has thinner tyres, so whether that's the diff or something else, I couldn't say
it seems to be of advantage to some cars but not others, perhaps the suspension you use too
but on my part, it's one of the best things that's helped traction for sure! and for 100 bux!
I have an R32 with stock suspension. To me the diff seems very tight, i don't know if it's normal or not, cuz i have nothing to compare with.
Anyhow, sometimes when i give my car stick around a corner, i get diff shutter (axle tramp??). Alot of people told me that was just because it was on the verge of not having enough power to fully slide out. But it seemed to happen whatever corner i tried to slide out of.
I haven't done it for awhile, due to the fuel factor.
Will pineapples help with this situation?
Yes they will help.
My cornering has been much more stable since installing the pineapples.
I have also noticed that wet weather driving is more consistant with the pineapples installed.
I have zero tyres on the back so of course that wouldn't help my situation! Still, I should be getting new 235mm tyres on some 17" rims on Friday, so that should improve handling on mine.
Improved sway bars (front and back) would definitely help. I had them on my old R31 and even though it had not much power, it handled pretty well for an old beast.
Guest nismogtsx
I am a 50/50 on pineapples....
My gf's 200sx has em and their ok, i drove it before an after and noticed that the rear felt tighter round corners... but it didnt feel natural and felt as though it might let go any second...
The pineapples reduced my confidence in taking corners hard...
Were they set up for all-round grip or straight-line grip? I've said it before in other pineapple threads and I'll say it again, all-round grip is the *only* way to set it up for a street car. Handling is comprised otherwise and I found it downright dangerous at times. Changing over from all-round to straight-line is a simple 30min exercise that you can do before a trip to the drags.
  • 1 month later...
$80 for installation is abit steep.
It should take a solid 30-40mins to install it and 25-30mins if they know what they are doing. (Surpisingly 2 suspension shops i went to had never seen them and no idea how to install them without the provided instructions).
Should probably cost you $170-180.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
