  • 7 months later...
  • 1 month later...
BYBY,
I am taking 200+rwkw to be about 310HP at the flywheel. I dont think the stock turbo can move this much air at 1bar. At least why would you go a 2530 for a power increase when they are rated at about 310/20 HP?
they are rated to that but we all know that a HKS2530 will support 250rwkw @ 1.5bar..HKS underrate there turbo's a fair bit
how do they make 250rwkw (backed up by a 11 sec pass) on a RB20 @ 1.5bar then?
if they can do it on a RB20, it can be done with a Rb25
it was 247rwkw but hey, whos counting
the stock R33 turbo will flow 200rwkw @ 1bar
Moving into less known territory here but I think because the RB20 requires less air. I'm guessing it would have to have less torque too but it's probably in a lighter car with who knows what other mods for an 11 second pass.
People here have tried it on an RB25 and despite others telling them that they can get 250 they never can. There is all sorts of talk about boost controllers and waste gates actuators but in the end it doesn't seem to be able to push enough air into the RB25.
I'm sure a stock turbo can push 200 rwkw at 1 bar, in fact, probably at a little under one bar.
I think I have been trying in the to say that (in the distant past) 200rwkw at 1 bar translates to 300hp at the motor or less. My speculation was about actual engine power. dyno readings are to me like peices of toilet paper when used for inane comparisons between cars. The 1/4 mile time for the Rb20 powered thingo is more interesting. I'd be more swayed to buying a turbo based on what it 'does' in the real world when setup correctly. ;)
Hey guys.... Im bulding a sub 11 sec car myself and noticed a few of you going for the davis craig thermos.... if you are looking for cheaper alternative, go for a 2nd hand vn-vs v6 thermo... i hooked mine up to the sensor on the manifold. The clutch fan uses more energy than you wood believe... and worse it sounds terrible when cold :P
Hi sorry I dont know if this has been mentioned yet but can you guys provide a DIY style info guide to removing fluid clutch style engine fan and how to replace with a thermo fan.
I'd like to give this a go if you guys say it produces more power but I havent got a clue how,
PRESA,
It doens't make more power but, rather reduces inertia. Makes the car accelerate faster anyway so who cares?
It's best if you remove the radiator. Once you have done that everthing is just an unbolt and bolt on affair. I'm sure if you have some experience working on your cars then it's too easy. If not a step by step is not going to help if you can't work out whats in front of you.
There are 4 bolts holding the cluth fan on. undo them whilst the fan belt is still on (holds the pulley in place).
With the radiator out this will be very easy.
line up the thermo fan on the radiator so as to retain the fan shroud (you must keep this to gain the maximum cooling effect).
Wire up the the connections needed and the relay ready for the thermo fan.
bolt it back up and fill with coolant , remember to bleed the air out.
test.
  • 6 months later...
I think I have been trying in the to say that (in the distant past) 200rwkw at 1 bar translates to 300hp at the motor or less. My speculation was about actual engine power. dyno readings are to me like peices of toilet paper when used for inane comparisons between cars. The 1/4 mile time for the Rb20 powered thingo is more interesting. I'd be more swayed to buying a turbo based on what it 'does' in the real world when setup correctly. :D
my opinion
200rwkw would be more than 300 engine hp.
300hp = 225kw. You would loose more than 25kw throught the drive train.
eg
standard r33 gtst engine power 187 and and 135rwkw rough estimation.Thats 52 KW. Id say 200rwkw would be closer to 250kw+ at the engine which is arround 335hp.
cheers
  • 4 months later...
Sold it before I got to the track again to try. The last run it ever did was 13.3@106mph and a 2.3 60ft (205 tyres), so in a nut shell with wider rear tyres a high 12 would have been pretty easy, the 60ft just needed to be about 2.1.
There are now quite a few r33's with stock turbo's that can lay claim to the 12 second title. I'm not sure if any of them did it with the stock intercooler though?
I've got a GTR work car now that is more fun to drive, I had to sell the GTST to get the GTR simple logic. The GTR will bolt in a mid 11 pretty easy. :P
I also had fitted a nitrous kit just before selling it and would have liked to have made a few passes with that on as well. 2rismo ended up with my old nitrous kit parts and after he added a few thing to it he got a stock turbo'd GTST into the 11's with a shot of the gas. Thats a good effort in anyones books.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
