I run the same fan J.
I fitted mine (16" DC & thermal s/w) new ~1.5-2 yrs back. It keeps the temp's under control even in 40+C traffic no prob's.
Normal water temp is ~80'C
Have hit a max of 92'c on a 32'c day after hrs worth of dyno tuning runs (hotter in the dyno cell!).
Matt - sweet.. That's what I like to hear.
Rev - I had a good look at it yesterday, and I don't think I'll be able to keep the shroud :) But I'll do my best to try and keep it, even if I have to chop it a bit. I let you know how I go on the weekend.
J
Originally posted by rev210
Another mod I'll add to the list is replacing the flexi tube between the turbo and the afm, probably with a metal pipe. The factory pipe is quite restrictive.
Guys,
Yeah I lost the shroud in my thermo set-up. Hasn't been a problem for my car though. I do intend making a flashy new one (one day :rolleyes:) A few hard laps of a track may be a different story, but I'd be going for a bigger better radiator if I got into track racing.
Rev,
Flexi tube - Yep ditched that a while back too :D Nasty looking piece of gear. I run a completely new metal intake pipe (nil AFM & all) From turbo to filter is custom fabricated.
Much thinner than the standard clutch fan. Easier to fit nice big FMIC pipes across the engine bay (inlet & outlet on opposite side style) without fouling the bonnet or stock fan blades.
You need to wire the thermo in with a relay, fuse (30A) & thermal s/w. There's plenty of room in the fuse box to fit the extra relay & fuse.
Below is an old (poor quality) pic of my inlet piping. The blue silicon Samco hose section actually has piping most of the way through it (nil chance of sucking in!) but a small section is allowed to flex, then the adapter for the K&N is on the other side.
Rev210 your chase for 12's will be difficult with the stock turbo and impossible with the stock intercooler, I doubt 10psi will get you 12's. Delay the little mods like fans,pulleys and cam gears and get a large FMIC, with the SAFC and an increase in boost a 30rwkw+ gain should be seen, if your still short then try the little things but the intercooler must be your next mod.
I worked out if I can get a 1.9 60ft , 104mph is enough to get 12.9 should I not fall asleep changing gears. Actually if I got a 1.9 60ft my mph would be higher than 104 and the time probably lower.
then again 1.9 60ft is a little hard to do on 205's.
Originally posted by GTS-t VSPEC
Nice engine bay, I don't have the problems with the piping due to a different plenum, so hopefully that will make the fan even easier to install.
See'ya:burnout:
Thanks mate. I've tarted it up a bit more since that pic.
With a Greddy plenum (or any front mounted TB manifold) the piping will be easy :rolleyes:
Whatisname,
Yeah, I have the Greddy plenum, and it makes working on the car that much simpler, especially removing spark plugs.
rev, I think that a set of 235's or 245's would be good for you, would allow much harder launches.
See'ya:burnout:
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
