I run the same fan J.
I fitted mine (16" DC & thermal s/w) new ~1.5-2 yrs back. It keeps the temp's under control even in 40+C traffic no prob's.
Normal water temp is ~80'C
Have hit a max of 92'c on a 32'c day after hrs worth of dyno tuning runs (hotter in the dyno cell!).
Matt - sweet.. That's what I like to hear.
Rev - I had a good look at it yesterday, and I don't think I'll be able to keep the shroud :) But I'll do my best to try and keep it, even if I have to chop it a bit. I let you know how I go on the weekend.
J
Originally posted by rev210
Another mod I'll add to the list is replacing the flexi tube between the turbo and the afm, probably with a metal pipe. The factory pipe is quite restrictive.
Guys,
Yeah I lost the shroud in my thermo set-up. Hasn't been a problem for my car though. I do intend making a flashy new one (one day :rolleyes:) A few hard laps of a track may be a different story, but I'd be going for a bigger better radiator if I got into track racing.
Rev,
Flexi tube - Yep ditched that a while back too :D Nasty looking piece of gear. I run a completely new metal intake pipe (nil AFM & all) From turbo to filter is custom fabricated.
Much thinner than the standard clutch fan. Easier to fit nice big FMIC pipes across the engine bay (inlet & outlet on opposite side style) without fouling the bonnet or stock fan blades.
You need to wire the thermo in with a relay, fuse (30A) & thermal s/w. There's plenty of room in the fuse box to fit the extra relay & fuse.
Below is an old (poor quality) pic of my inlet piping. The blue silicon Samco hose section actually has piping most of the way through it (nil chance of sucking in!) but a small section is allowed to flex, then the adapter for the K&N is on the other side.
Rev210 your chase for 12's will be difficult with the stock turbo and impossible with the stock intercooler, I doubt 10psi will get you 12's. Delay the little mods like fans,pulleys and cam gears and get a large FMIC, with the SAFC and an increase in boost a 30rwkw+ gain should be seen, if your still short then try the little things but the intercooler must be your next mod.
I worked out if I can get a 1.9 60ft , 104mph is enough to get 12.9 should I not fall asleep changing gears. Actually if I got a 1.9 60ft my mph would be higher than 104 and the time probably lower.
then again 1.9 60ft is a little hard to do on 205's.
Originally posted by GTS-t VSPEC
Nice engine bay, I don't have the problems with the piping due to a different plenum, so hopefully that will make the fan even easier to install.
See'ya:burnout:
Thanks mate. I've tarted it up a bit more since that pic.
With a Greddy plenum (or any front mounted TB manifold) the piping will be easy :rolleyes:
Whatisname,
Yeah, I have the Greddy plenum, and it makes working on the car that much simpler, especially removing spark plugs.
rev, I think that a set of 235's or 245's would be good for you, would allow much harder launches.
See'ya:burnout:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
