Traction problems are the bane of all GTS-t owners, especially those making decent power :)
I think after you go past a certain power level, there really is nothing you can do on street tyres. Nitto NT555Rs perhaps, but slicks to do it properly.
For all those who whinge and say "Buh, it's a street car, you should run it on street tyres"... I understand where you're coming from, but your car is not making enough power for it to be an issue. If it were, you would know why slicks are necessary.
There is a point where street tyres are useless. 600rwkw in a RWD car, of course you're going to have to use slicks. 160rwkw, you won't. Somewhere between the two, is a line where street tyres become futile for drags.
Anyway, that's an AWESOME mph Matt!
Congratulations!
Thanks guys - I'm just glad to finally get it out to the track and have a time to work on! Bring on the nitto's and bring on the 11's!
You're right about traction problems though - even after doing a burnout in staging, I had f#$k all grip (or boost) till 3rd gear. My best run I was actually slipping the clutch all the way through second gear so I could load up the engine to get boost... Otherwise it would bog down on the change into 2nd and 3rd... It was spinning into 4th at 160 which is certainly exiting :)
matt
First things first mate - TOP BLOODY EFFORT Matty! Like Andrew said, that mph is awesome.
Forget all other road rubber & go with NT555R's. If you can't get the power down till 3rd then it's either Nittos or slicks for you (see Andrews comments below).
I don't know if the clutch I went with is going to last very long with the power your car is making? It has a claimed 600hp on it though. I'm not sure exactly what the pressure plate is rated at with the off-the-shelf version but I requested ~1100kg (this was too much for my master/slave cylinders so they needed to be O/H'd). It's a little on/off but still very easy to live with. I've not stalled the car since fitting it :P Most importantly I haven't had it slip even after a few hard launches (1 on the strip the rest on the street).
Here's a link to the clutch kit on Tim's site http://www.horsepowerinabox.com/mall/ck06.asp
Here's the straight button version - http://www.horsepowerinabox.com/mall/ck05.asp
Some of the forum guys are talking a group buy on the HIAB cushion button (same one as mine). It retails for $750, Tim will do it for $730 & group buy less again.
Do a search on “clutch” & you should find a few threads on the ACS/Xtreme clutch (HIAB kit)
Cheers,
Matt
If you guys are interested, I ordered a pair of Nitto NT555Rs in 245/50/16 from the states.
They're brand new, and cost me $675.20 for the pair, which is an AWESOME mates rates price.
I'm in the process of selling my GTS-t, so I'm willing to sell these tyres to one of you guys if you want them...
I also have two R32 GTR rims (16x8) in perfect condition that I was going to mount the Nittos on. I bought these for $500.
If you guys are interested, drop me an email at [email protected]
Matt, heh thanks - I was a bit worried going out that the car wouldn't live up to expectations. But after a 13.1 first run, I ran 12.7-12.9 fairly consistantly with my 2nd last run being the best, and the final well... slipping...
600hp is all my cars making anyways, so I'm guessing that it'd probably do the job... Up till now, the car has had only a full faced organic in it, so I'm not in any hurry to put a twin plate etc in as I don't want to risk the gearbox.
Merli, you have email :P
matt
yeah... on the issue of street tyres being useful/useless.
R31's suffer from grip problems too :P
same as a 33... if you have a 33 engine that is :P
I think once you come to the 250rwkw + your really gonna start to push the limits where by you'll probably go slower than when you had less power as you could get it to ground far easier (and safer)
i've got 190rwkw and i can now skate the whole of second if i'm quick to the change, so once i get boost and get prob around 250rwkw i think it's gonna start to get to the stage where power just cancel's out grip entirely.
Excuse the ignorance... Are these nitto's better than semi comp's ?? The look more of a 'street' style tread more so that semi's.
Hi guys, there is always a lot of talk about not being able to get the power to the ground. Tyres crop up from time to time, but hardley anyone talks about suspension set up.
I did a proper rear wheel alignment and geometry set up on R33 GTS late last year and it was 0.5 second faster over the 1/4 with the same power, tyres, weight etc. I did not change the springs or the dampers, just got the wheels pointing where they should be.
I see lots of Skylines that are too low, have too much negative camber, too much drive shaft angle, too hard a spring rate, not enough rebound damping etc.
It has been my experience that most Japanese road/track suspension kits have way too high a spring rate in the rear for a drag car. The dampers have too much bump rate and not enough rebound, result is lots of axle tramp.
If you are serious about getting a quick 1/4 time, then make sure your suspension is set up for it. Otherwise you are simply wasting your time forking out big bucks for power you can't use.
After adjustments the R33 GTST geometry looked like this;
Front
wheel centre to guard – 355 mm
RH Camber – 1.0 degrees negative
LH Camber – 1.0 degrees negative
RH Caster – 5.5 degrees positive
LH Caster – 6.0 degrees positive
Toe – out 1.0 mm each side
Rear
wheel centre to guard – 340 mm
RH Camber – 0.0 degrees negative
LH Camber – 0.0 degrees negative
Toe – in 0.0 mm each side
Hope that stimulates some discussion.
Front
Rear
SydneyKid - thanks for those figures - I'll be using them in about a month or so when I change my suspension :D
Just a quick question. Are these settings suitable for normal street driving, and will using these settings sacrifice handling in the twisties badly at all???
I just thought I'd ask cause I thought it was normal to have toe in on the front, not toe out..
Thanks
Jayson
hhmm... Sydney kid...
do you know a Melbourne Kid (j/k) at all that knows this sorta stuff???
Cause the R31 is different i would say and i do know that suspension plays a just as important part as the tyres, but then finding someone that REALLY knows, and doesn't just say they know, isn't easy.
I've already gone to the trouble of aligning the rear camber as neutral as possible. I've lost count of the aligning sessions to get a good set up for road & strip. And I've fitted grippy rear rubber.
Front
Rear
I completely agree with you.
Unfortunately compromises must be made. I MUCH prefer circuit racing to drag racing, and as such, my car has hard coilovers, thick sway bars and alignment set for optimal cornering.
I'm not willing to put 90/10 suspension in the car just to get that squat and launch, because....... I guess that goes against what I want the car for.
I'm happy to extract the best times possible out of my circuit racing setup, and realise that much better launches and 60 footers can be achieved with proper drag racing suspension, but I'm just not that serious about drag racing.
For those who are serious about their straight line times, SydneyKid has provided priceless information :uh-huh: Cheers!
But 90% track, 10% drags is my motto :)
Merli,
I agree with you there spot on! My car was built as it is to be a quick street car/circuit car, as such, it's got harder suspension which is good for the twisties... If it can pull a quick time at the drags, I guess that's just a nice bonus!
I think the skylines make a shitty base for a drag car... They're just too heavy.
matt
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
