The guy had been recommended and I had used him before to respray the rear wing. I was happy with the job he did, so I didn't bother with other quotes.
Yes, the car is as you deciphered (engine is from a Stagea).
I guess I am considering a Stagea conversion in my GTS4. What did you pay for the engine? Is it stock? Which turbo did you go with? Did you do the swap yourself? Have you driven a GTR - does it compare? If you had it to do again considering the cost and result would you do it?
Lots of questions for enquiring minds.
$500 is way too much
There is a place in bayswater that will respray an entire car in 2-pak oven baked enamel for $599.....
Expect $100-150ish for just a front bar, just get a few quotes. Front bar is easy-as, because you can take the whole thing off the car, and don't have to remove any trims or anything.
Just go around a few panel beaters, and get some prices. don't pay $500, a front bar isn't hard to do at all.
true, but for spraying a front bar. not much to screw up. u can spend 3 hours doing it and it will be perfect. so depends on how much they charge per hour, and what paint they use.
Plus you mentioned your cost included some modifications, so hard to compare what it would cost for just the respray...
Depends where you live....i paid 350 for my vertex front bar to be sprayed, they cleaned it up made the lines flow, put to layers of undercoat on the fibreglass so that the actual paint would stick, then they sprayed it in the skyline burgandy (wine) colour and clear coated it.......looks better then my cars paint lol...and i thought 350 was a jip..CHAMPION CRASH REPAIRS ADELAIDE
ye $500 is too steep, u can buy your own spray painting gear and paint for that and still have money left over. My mate bought his own compressor, paint, sprayer and did his own spraying and came out good.
$500 to spray a front bar alone is very high and far from normal...i'd expect to pay anywhere between $250-300 for a GOOD job...
goodluck
Yeah it is expensive, but if you want a proper job you have to pay for it.
I personally have had a few spray jobs done...the basic price for this place i go to is $200 per panel or part...and the work is top notch...you'll be hard pressed to find workmanship of this calibre even at higher prices...i'm a firm believer of the saying "you get what you pay for" too...made that mistake before...krzysiu...since you're in melbourne too...if you ever need some work done...drop me a PM...i can guarantee you won't be disappointed with the quality of work done at this place....
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
