  • Replies 49
got the winfield from gamesworld in rockingham it was $129 that was 15 months ago.
got the calsonic from Triking Stamps and Models (hey st Perth Wesley arcade) $99
yeah the calsonic is the 100th edition model from kyosho
the winfield is a kyosho special aswell.
NeoNode
Love it :D
Jon R33
answered above
BoOsTeD_RB26
above and theres a couple more i've seen. the calsonic in a lighter blue, and a black and green stripped one (only seen on a website and they were sold out.)
INASNT
i got 3 gtrs the ones pictures plus i got 12 others
Corrolla WRC rally Aus version
Lambougini Diablo SV
Lambougini Countach
Calloway C12
BMW M3
BMW Z3
Mercedes SLK Kompressor
Ferrari 360 Mondena
Ferrari Testarossa
Jaguar XK 180
Toyota Supra MKIV (bloody hard to find at the time seen more around now)
and a Team Exxon Racing Dodge Viper
hako
yeah i doubt its one of 10 maybe one of 10 he had
NeoNode
Love it :D
Jon R33
answered above
BoOsTeD_RB26
INASNT
Lambougini Countach
Calloway C12
BMW M3
BMW Z3
Ferrari 360 Mondena
Ferrari Testarossa
Jaguar XK 180
hako
nice!
now dont u wish u had a warehouse with all those real cars in there???:eek:
Originally posted by EnricoPalazzo
I have the frenetic model Skyline like someone said. Ive had it for like 6 months and its still in pieces after i took it apart and tried to get the Stage 3 turbo kit to work
Dammit
If only i could be stuffed fixing it.
Ahwell someday.
haha were in the same boat... did you get stage2 to work?
i got that working then went to put in stage3 and gave up.
Shaun
Was just checking out ebay and they have a Biante (???) model Winfield R32 GTR in box with brochures and stuff for $305 and the bids are still going up
They also got those real small RC Skylines too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
