Cool. U know after installing the hid kit, i swear Nissan pple were thinking, well well, let's make 1 side of the light hard to change than the other! And that pple with fat hand's can't change it easily. Let's just put stuff around it.
Sheesh. This is the first car i've experienced changing a bloody lightbulb is so troublesome. Thank god i've got xenons now, if it really lasts the full lifetime, i will never have to change it.
  • Replies 59
Posted Images
Got my hid installed, took 2 hrs, and am quite happy!! The only problem is... My lens is too dirty/oxidised!! The inside not the outside... and now my parkers really look oxidised. FUG. Back to the ol drawing board.
My lens is a bit dirty on the inside too. My parkers are almost the same as blinkers now compared to the HID's. We should see if anyone can source whiter park lights.
Im putting my name for a set already, just so its less noticable that you have hids
I'm goin back home to get my set of white park lights. It's much cheaper back home. Also when i come back to aussie, during the first week, the first thing i'm gonna do is to take out the headlights, strip them apart and give them a good clean inside and out + seal.
Not 100% required, but if ur fuse ever do blow, do change to 15A fuse. I believe due to this kit having the relay, there is no need for a fuse, and the relay already has a fuse. So might not need the 15A fuse, but i might be wrong. I'm still gonna get 15A fuses to standby just in case.
so. how has everyones installs gone?
i only got mine a couple of days ago and just wanted some feed back as to how the installs went, whether those with a r33 h1's used the relay kit and had no stabilization problems, and how the hid's look in general.
pics of how you mounted the balasts would be great too
Thanks,
Nate
  • 4 weeks later...
Anyone installed to a R34 ?
The red wire in the headlight is connected to the halogen globe, but the black one is connected to the housing ?
Do we have to cut it the black wire to connect to the HID kit ?
Edited by Manwh0re
i put the relay harness in when i installed my hid kit.. i connected the positive to the battery and earthed the negative to the body of the car. been driving around for a few days now, but just last night i started noticing the lights start to flicker going brighter/darker sometimes? anyone know why its flickering even with the relay harness on?
I suggest that you check you earth connection as it may not have a good connection.
Best thing is to connect the earth side to the battery as well.
Spent this afternoon installing my HIDs with the kind help of my brother. Heres some pics to share.
as you can see, the parkers are now an absolute joke hah. need to buy some white LED parkers.
I have to wait a few more hours before I can test them at night :( but so far they look awesome even with my filthy light lens, prolly go clean that now.
And thankyou once again bankids :)
hrm hrm.. and for the install guide ? :(
Yeh.. they make the parkers look like indicators they're that bright. Night time they light up the whole road, very nice indeed. I clean mine usually with cut and polish and use some wax after on it.
I also installed mine today. Very happy with the lights as they look in the daylight, can't wait to see them in a few hours...Cheers to my bro for the help installing and damono for the install guide. All up only took us about 20-25mins. Too easy.
  • 3 weeks later...
is it just me? or does everyone else who installed their hids, now get flashed from time to time by other drivers, assuming I must have my highbeams on.
I parked my car side by side with my step mums commodore, to see the lights in comparison. the HIDs dont go much further, just way more intence. I guess its enough to have people think they are highbeams :S
normally hid should come with the projector lens, coz the light wave length is different of halogens, and all the normal lights assembly were designed for normal halogens so might not control the hid lights as good as halogens.
but i think that's because the lights are too bright because i saw many halogens also blinds my eyes..
  • 1 month later...
You'll notice that aftermarket HID lights are very bright,, for oncoming traffic,,
A glare shield can usually fix this,, but i can't seem to find any DIY Glare shields to suit the r33/r34 the (H1 bulbs),,
Anyone got any ideas on how to make a glare shield for the r33/r34's?
there are heaps of diy's on google for the dc2 type plug,,, usually for honda's and stuff,,,,,
Edited by AFRO
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
