http://www.importforums.com/information.htm
the R32 GTST 400m times of 14.63???
mine has a zorst, running 10psi and remapped ECU and POD and would only just get into the 14s... some semi slicks as well and then maybe that time would be true... then again im not the best launcher in the world.
https://www.sau.com.au/forums/topic/9470-these-stats-cant-be-right/
My GTS-4 Sedan Auto, Very stock (Just Cheap pod filter and cold air induction) has run a 15.4 in very hot conditions, after a few runs, I am very sure with a good launch and the right conditions I could run 15 flat.
A manual r32 GTS-t Coupe could run a 14.6.
Greg.
absolutely stock?
those times are meant to be for STOCK cars.... when i took mine the first time when all it had was a zorst and nothing else it ran a 15.5 on a coldish night... i spose with decent wheels it maybe able to do a 15.0 but that still isnt stock
Mine ran 14.6 with a cat back exhaust, blitz ECU, air pod, stock turbo, 11psi. This was on a night that i broke it on my 6th run, no compression in cylinder 6 (2 valves burnt). After fixing it we discovered that it had been running for a while with lower comp in that cylinder, so it was a tad down on power. Feels quicker now that its all fixed up.
If i tried again with a bit of practice I might get it down to a 14.4. While the figure the site stipulates is probably now a genuine stock time... its not THAT far off. However their weight listed is also a bit off the mark (i believe the 32 gtst weights 1350-80?)
Red17
But i dont see the point in hammering the car when I havent changed anything that would make it go any faster :)
I ran a 14.2 with cat back exhaust/filter and standard boost.!!
2.1 ish 60 foot. and I had ran a 1.9 earlier in the night. So theoretically it was good for a 14 flat if i could get the same launch..
With full exhaust/tune/pump/boost I am hoping for hi to maybe mid 13 with a good launch
Originally posted by Duncan
I ran 14.3 with stock zorst, stock airbox, stock everything except 9psi boost.  R33 gtst, we all know they are better :uh-huh:
butt uglier.
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
