http://www.importforums.com/information.htm
the R32 GTST 400m times of 14.63???
mine has a zorst, running 10psi and remapped ECU and POD and would only just get into the 14s... some semi slicks as well and then maybe that time would be true... then again im not the best launcher in the world.
https://www.sau.com.au/forums/topic/9470-these-stats-cant-be-right/
My GTS-4 Sedan Auto, Very stock (Just Cheap pod filter and cold air induction) has run a 15.4 in very hot conditions, after a few runs, I am very sure with a good launch and the right conditions I could run 15 flat.
A manual r32 GTS-t Coupe could run a 14.6.
Greg.
absolutely stock?
those times are meant to be for STOCK cars.... when i took mine the first time when all it had was a zorst and nothing else it ran a 15.5 on a coldish night... i spose with decent wheels it maybe able to do a 15.0 but that still isnt stock
Mine ran 14.6 with a cat back exhaust, blitz ECU, air pod, stock turbo, 11psi. This was on a night that i broke it on my 6th run, no compression in cylinder 6 (2 valves burnt). After fixing it we discovered that it had been running for a while with lower comp in that cylinder, so it was a tad down on power. Feels quicker now that its all fixed up.
If i tried again with a bit of practice I might get it down to a 14.4. While the figure the site stipulates is probably now a genuine stock time... its not THAT far off. However their weight listed is also a bit off the mark (i believe the 32 gtst weights 1350-80?)
Red17
But i dont see the point in hammering the car when I havent changed anything that would make it go any faster :)
I ran a 14.2 with cat back exhaust/filter and standard boost.!!
2.1 ish 60 foot. and I had ran a 1.9 earlier in the night. So theoretically it was good for a 14 flat if i could get the same launch..
With full exhaust/tune/pump/boost I am hoping for hi to maybe mid 13 with a good launch
Originally posted by Duncan
I ran 14.3 with stock zorst, stock airbox, stock everything except 9psi boost.  R33 gtst, we all know they are better :uh-huh:
butt uglier.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
