Cheers Siks.
By the way you've been doing a top job of this and I would just like to say thanks
Trev
Thanks a lot i appreciate you telling me, and all others have have said so to and i appreciate that :D
  • Replies 134
ok the two guys (ryno and fat32) who needed the temp sensor will get the fitting in their cats, i said dont bother for the rest of you since you said it was ok without.
I went down to magic today with d00dz to see what the issue was and see his cat get fitted. His original cat was still intact around the sensor area so magic could see how to make the fitting for the temp sensor.
I saw a finished bolt on cat and they look good, and fitted perfectly to d00dz's(victor) car so they should fit easy :)
The second order has been put in so everyone's cats have been ordered, and will be made up and sent early next week.
people should post up remap dyno results with magic cat, would be very interesting to see peoples results.
This is what i wanted to do, as i need a tune anyway, but i am a but short of $$ so im not sure if i will bother as it means extra time to come on and off the dyno, get the guys to fit the cat, then back onto the dyno :)
some pics ;)
Edited by siksII
im interested in one of these cats. not sure which one, where is the shop? do you get an sau discount if you go in? and will there be another group buy?
Hey if you give them a call and mention the group buy, or go in and mention the group buy as long as its soon they will look after you.
I have a 33 GTST with a 3" from the turbo back zorst... Will this bolt straight on?
How much power increase does it give you? (in kw)
How many km's you getting out of a tank these days doodz :(
If you went to the effort of reading the first post :D you would know that the 3inch bolt on version does bolt onto a 3inch exhaust, but just the cat will not. Group buy is officially over anyway, but magic said its ok if u call them and say you are late for the GB they will look after you as long as its soon.
KW depends on car and cat currently in use. Could be a few or many.
Just curious, are we ( ryno & I ) likely to see ours before xmas ? Not buggin or hasseling etc. Just wondering cause I've got to do a service soon and it would be great to install the big cat while it's off the ground. :P
Hey mate, as far as they told me they would have sorted yours out a couple of days ago. If not you can give them a call and ask them, but im sure u will get them soon. If you are really worried i can give them a call for you no problems...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
