Cheers Siks.
By the way you've been doing a top job of this and I would just like to say thanks
Trev
Thanks a lot i appreciate you telling me, and all others have have said so to and i appreciate that :D
  • Replies 134
ok the two guys (ryno and fat32) who needed the temp sensor will get the fitting in their cats, i said dont bother for the rest of you since you said it was ok without.
I went down to magic today with d00dz to see what the issue was and see his cat get fitted. His original cat was still intact around the sensor area so magic could see how to make the fitting for the temp sensor.
I saw a finished bolt on cat and they look good, and fitted perfectly to d00dz's(victor) car so they should fit easy :)
The second order has been put in so everyone's cats have been ordered, and will be made up and sent early next week.
people should post up remap dyno results with magic cat, would be very interesting to see peoples results.
This is what i wanted to do, as i need a tune anyway, but i am a but short of $$ so im not sure if i will bother as it means extra time to come on and off the dyno, get the guys to fit the cat, then back onto the dyno :)
some pics ;)
Edited by siksII
im interested in one of these cats. not sure which one, where is the shop? do you get an sau discount if you go in? and will there be another group buy?
Hey if you give them a call and mention the group buy, or go in and mention the group buy as long as its soon they will look after you.
I have a 33 GTST with a 3" from the turbo back zorst... Will this bolt straight on?
How much power increase does it give you? (in kw)
How many km's you getting out of a tank these days doodz :(
If you went to the effort of reading the first post :D you would know that the 3inch bolt on version does bolt onto a 3inch exhaust, but just the cat will not. Group buy is officially over anyway, but magic said its ok if u call them and say you are late for the GB they will look after you as long as its soon.
KW depends on car and cat currently in use. Could be a few or many.
Just curious, are we ( ryno & I ) likely to see ours before xmas ? Not buggin or hasseling etc. Just wondering cause I've got to do a service soon and it would be great to install the big cat while it's off the ground. :P
Hey mate, as far as they told me they would have sorted yours out a couple of days ago. If not you can give them a call and ask them, but im sure u will get them soon. If you are really worried i can give them a call for you no problems...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
