Hi all, I am after a new turbo timer and was wondering if theres a good one to go for. I have had a bit of a search and found this one to do the job and it the cheapest I could find
http://www.nengun.com/catalogue/product/18
Is it worth spending a bit more for more features?, I don't know where I would put one of those TT units if I got one so I like the long thin ones coz thats what I have at the mo
cheers
Tom
https://www.sau.com.au/forums/topic/94887-i-need-a-new-turbo-timer/
yeah, I wouldn't need anything like that, just a normal TT that keeps the engine running for programmable times....I guess the cheaper the better for me so can I get a new TT for less than the $85 for the Apexi one I linked?
EDIT: actually it comes to $130 with shipping from Japan
hahaha... i can understand how u feel on 2nd hand parts, ESP electronics. Personally, i wouldn't go that way either, unless i'm really hard up for it and it's wayy out of my budget. And try not to buy off ebay either, some dude got a reconditioned one, that sold as new, cause when the workshop opend up the apexi turbotimer, there were burnt marks and resoldering.
no offence to RR, but I'd rather buy new than secondhand
thanks anyway though  :O
http://www.nengun.com/catalogue/product/114
Tom check if that's compatible with your car. I bought this a while ago from Nengun, sitting in a drawer & hasn't been installed. I just sit in my car for a bit, basically because you only need these when you are putting pressure on the turbo a fair bit, and letting the car idle for about 2 minutes isn't all that hard to do. Different case with 2 turbos I guess. :O
It costs $101 delivered to you in like 2-3 weeks from Nengun, $100 from me pretty much straight away, because you are just over in Beldon if you want it? It's new, in box, I opened it to have a look & that but didn't do jack shit with it.
Not talking about your penis are you? :lol:
lol :) , with that extracted from the sentence it would appear so. But no :D
ossie_21, how the hell does the shipping for that come to less than the Apexi onw which is smaller? :D and yeah, its compatible with my car
what the optional harness there?
The other thing is installing it, because I will need to tie it in with my alarm. I guess one option is taking it back to Action Alarms and get them to install it coz they tied my current TT in with the alarm when they installed it...
This timer looks bigger than it is (not another penis joke please :D ), it isn't all that big. I'm sure the same people that did your other one could do whatever you decide to get.
My turbotimer is installed with a bypass.. or rather my alarm Laserline top of the range has a bypass to allow me to lock the car while the engine is still running on the turbotimer and it'll automatically immobilise after the turbotimer dies. Which is pretty good i feel.
Thats what my Cheetah 777 alarm does, so maybe its best I take my new TT to the place that did my alarm....
sorry BNR34 I wants new :(
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
