i think a skyline needs a subtle kit, thats not over the top, yet can make it look aggressive. i'll post up a pic of what i mean soon.....
oem look is king for skylines, why mess with something that looks appealing from the factory? I'm really motivated to buy a 400r front bar, but I'm not sure about fibreglass & places I was considering buying from eg. Carmate have had some negative comments ;)
https://www.sau.com.au/forums/topic/94896-body-kits/#findComment-1716349
Does anybody know where i can get in contact with do luck i ahve sent a email to do luck USA and got nothing back <_<  any help would be great. :P
i have enquired with a genuine distributor... it will cost somewhere close to 8g's (the cheapest i have found so far) to bring the kit in (tax = 25%, shipping, insurance)
it will then still need to be prepped and painted... if your still keen pm me
eug
https://www.sau.com.au/forums/topic/94896-body-kits/#findComment-1716709
I put this kit on my car
GP sports
Would have prefered the Duluck kit, but it was too exspensive.
i'm in the same position in regards to wanting do luck, but just can't justify the cost.
got any pics of the gp sports kit on your car? was lookin at that site recently, all the cars are dropped almost to ground level to make the kit look better. would be good to see it if you have a pic
https://www.sau.com.au/forums/topic/94896-body-kits/#findComment-1716740
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
