Hi guys
someone can take my place - i will be selling Niz hopefully early this year so will resist the urge to thrash. She's at the shops today getting new tyres, new suspension and a few other bits n pieces as it is.
Oh no! are you upgrading or moving to somthing different?
  • Replies 199
not really place to discuss but will just answer your question quickly: I plan to do a little bit of both - upgrade with something a little different (don't worry still a nissan) its a project i've been itching to do for the past 18months. Won't be upgrading straight after the sale of Niz - will take me about 6 months later to get the funds together.
No i won't be selling the plates either :)
sry guyz n girlz, looks like after waiting so long for this event to arrive, i wont be able to join ya's. car is unfortunately out of action for a couple of wks. clutch has started to slip a bit, so decided to replace and upgrade whilst im fixing it. might try come down and watch, but if i cant have a great night.
Liz/Dan, will times be posted on the forum after the event?
A few questions..
1. What would you say would be a good tyre pressure for 18x265x35 tyres on a R33 GTST
2. Does octane booster really make a difference?
3. I have a fat head, does anybody have a spare helmet I could borrow?
4. How much petrol should be have in our tanks.. 1/4 tank before the night, i dont want to carry too much cos of the weight, but i wouldnt want to run out.
Cheers
damo
Topaz - the entrance is VERY obvious. You drive in off Anketell Rd and there are BIG signs saying 'competitor entry'. You go through the gates there and pay the person in the booth :P So as you turn into the motorplex rd off anketell, its your first right turn into the gates.
Topaz - the entrance is VERY obvious. You drive in off Anketell Rd and there are BIG signs saying 'competitor entry'. You go through the gates there and pay the person in the booth :( So as you turn into the motorplex rd off anketell, its your first right turn into the gates.
ok cheers Liz ;), Ive been only once before when I was about 14-15 or something....
Wheres the closest petrol station? :mellow:. I should have about 1/4 of a tank on the night as well
Theres a 'better choice' servo just around the corner on rockingham rd towards perth direction but they sell poor ass fuel, theres definately no ultimate 98 or vortex. Actually.. come to think of it.. theres a Caltex just across the road from that one.
Wheres the closest petrol station? :). I should have about 1/4 of a tank on the night as well
The nearest BP is on Gilmore ave, which runs off thomas road. From Anketell you would go back to the roundabout (Abercrombie) and turn right, follow to end and turn left onto Thomas, right at the traffic lights onto Gilmore and follow to the BP. It's not very far from the plex, probably 2 or 3 km's....
For people coming from NOR down the freeway i'd suggest a fillup at BP THOMPSONS LAKE (Gateways Shopping centre).
Exit the freeway at Beeliar / Armadale Rd just on RH Side of Bridge is BP
Then Jump back on Freeway :unsure:
BTW, IMHO Octane Boosters are waste of time unless you are planning to run more boost, Advance your timing or you basically think you are going to get Detonation on the night, putting Octane booster into your 10psi Boosted Skyline will do nothing :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
