take out the spare wheel, rip out the plastic covering, fibreglass 1 sub in each corner of boot, make up a amp rack in the middle, done :D.
I have designs for a 12" side install sealed sub box too.
it can b done if u know what your doin, if any of u guys went 2 autosalon final battle 04 there was a silver r33 with full jl audio install 2x 12'' subs in the corners and 2 amps down the centre all fibreglassed and sprayed in r34 blue. this r33 is my own car and ill try get some pics up 4 u guys
why 1 sub per amp?
2 subs per amp better... lower impedance more crunk foe ya system...
use 2 x 2ohm subs (Assuming they are Dual Voice Coils), run your monoblock at 1ohm.. a good 1kw RMS of power... considering the monoblock does 1 ohm stable...
thats more power than 2 subs running off 2 amps
Please do
it has a normal size one, like u would find in the engine bay of an commodore for example, also with rca'z what length is reccomended, i was thinking something about 12ft/4m is this right???
im running 4 gauge wiring into a distro block then thats going to each amp 1 monoblock and 1 4ch
system is 2 audiobahn 12z, kenwood 9152d monoblock, clarion 4ch, alpine type s splits for front and rear, and a pioneer audiovisual headunit
thanks
You can fit 'em in, but I would recomend to dump em for some 6.5 or whatever the factory size is as 6x9's are a good comprimise for getting bass without wanting a sub. You have 2 subs so I wouldn't worry about trying to fit 6x9's. If you do however you may need to bend/cut the parcel tray, which I definatley wouldn't recomend.
I'd runn 4g for each amp to a distro block, then 2 or 1g to the battery. Looks like you'll be getting some juice going into your system. Don't forget to fuse it correctly as close to the battery as possible.
ok, yeah ill prob go get a length of it and do that, as my amps are gonna be sitting on the sides of the boot
after spending a few hours working out measurements and all that stuff for my sub boxes, ive marked out everything in my boot, im gonna be making my sub boxes up next week as im going for my ps on monday so i wanna practice as much as possible
ill post pics up once the boot is carpeted
thanks
