  • Replies 96
here's the prices for the units and the accessories providing you get 5 or more:
1.5W CB - $64.70
4 x Ni-MH Rechargeable Battery AAA 900mAh - $7
VOX Headset + Microphone - $10.70
Mains Charger - $10.70
Cigarette Charger - $10.70
Carry Pouch - $5.45
I recommend you get a mains charger if you don't have a AAA battery charger already as the cigarette charger I found gets in the way of the headset. Its only useful in emergencies.
Also if you want the items mailed to you it should be about $10. Seeing as you guys are all in melb, just organise to meet up with me at an event or monthly meet.
So what's your recomendation? Get the unit, batt, main charger! Do we really need the headset? Cigi charger seem to be alright though!
I use the VOX headset whenever I can... especially awesome when cruising.
I've got a standalone battery charger (which I got from Kmart), and take 8 rechargeables with me, 4 in the CB and 4 in the glovebox, just in case. I used to use the cigarette charger, but found it really inconvenient due to the design of the CB (cig charger plugs in where the VOX headset does) plus it takes forever to charge.
as long as the GB is over $100 and there's 5 or more of each item, those prices are valid. So yeah you guys should get em (the main units) off ebay if they're cheaper.
I'm not makin any money on em so I don't give a rats arse :D
lol, so are you doing the buying for all the people on this list nark?
i can say for certain that if i was gonna pay $65 for 1, ill pay $55 for 1...
and as for the accessories, if everyone gets the charger, in car charger, batteries we should be close to $100. anyone wanna do the math?
check the prices on accecories here
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
batteries like $5 and at no extra charge in shipping... will see if i can get as many as possible and avaerage the price out so they end up even cheaper
go go gadget Ni.
well the list of those that want them are above...maybe we should all add what accesories we want to make it easier for ni.
ill start, just copy the list and add what things u want next to ur name
1. Abusd
2. Dezz- main unit. cig charger. normal charger. batteries
3. West
4. West
5. West
6. Ferni
7. Mavric
8. Saff_cossie
edited justin off the list
i was doing some searching...
vic police use (or did use) 468mhz....
i know the ones in the groupbuy wont be able to pick that up..
but if i had a cb that could get that frequency... anyone no if the police still use 468mhz ??????
dam im going to miss out on those ones i just posted a link to cause i'll be on my way home....
would probably be able to get em for $60 for the pair plus delivery of 12.... so about 38.50 each plus the accessories on top.
spewin
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
