I dont know you might get 5 or 10 hp more maby and again it looks like a good safe tune
the next stage is ecu and igectors + pump so there is only so much hp out of some mods
go the shift kit and auto oil cooler and you might get a couple more hp
but with no 1/4 mile tests it is hard to say
Rev210 got into the 13s with not much more hp
james
  • Replies 101
Rev210's was an R33.. Different kettle of fish. :D
I believe Rev210 also had a few little aero mods, you know those little plastic bits that box off the stock intercooler? Rip those suckers out to stop it acting like a plastic bag in the wind.
Edited by Cubes
was that with a auto Miller?
my car has injector and fuel pump if thats wat your saying, and being auto makes after market ecu a bit hard, i would say the rom tune owuld be just as good anyway which is what i ahve got
What do you mean cubes? wat plastic i am a bit lost.
Edited by AntonRx7
No manual but is it hp and lack of it you are worried about not wat gear box it has
Emanage with inginion harnes for computer and the plastic behind your intercooler wheel arch thing rhs behind cooler pull that off
mine is auto so this thread intreast me
james
ohok umm maybe its different for r32 our cooler are on the passenger side and the old intercoolre is all gone.
Yeah i figure most people don't both with autos but i brought my car cause its in such good condition and though i'd give it a go at modding
I had to rotate the turbo housing cause BHDAVE had a himount manfold or something. Could the seal be leaking since i have done this and cause any problems. I doubt it cause air fuel ratios were good hyperdrive said and seems to hold boost fairly well. Also had a small crack in cooler piping but i patched it up with silcon hosing and put like 4 hose clamps on it (bit of over kill) but i don't htink its leaking
Edited by AntonRx7
took it for a drive just then it umm hard to expaain think its the limiter and it helps it change gear if you just take your foot of th accelerator a bit otherwise it take a bit longer to change gear
Also when i started car up it was a very very laggy/slugish for about 40second maybe it had a bit of water from when i cleaned the car though will see if it happens tomorow morning before walk
stupid cars
Edited by AntonRx7
i dono they defently didn't use much fuel as i filled it up before tune and the needle was still on full when i picked the car up. Maybe ill go speak to them thursday when i have a day off see wat they think about it. They don't seem to think it is capable of more HP due to turbo and gearbox thats wat they said when i picked it up
Short of the box being absolutely rooted, i can't see how that would be the problem, maybe the torque converter is slipping excessively? Is it worth seeing a gearbox specialist to rule out gearbox issues?
And the gcg highflows are capable of 250rwkw on rb25's so i don't see why 200+ isn't possible on an rb20 (and that's being conservative). The turbo made 199 on my rb25 at 14psi before i swapped it, that was only a couple of months before you got it. That was with 10:1 mixtures and no tune.
Who is good in perth with skyline gearboxs
i need a shift kit aswell but that needs to come from sa
there are a lot of autos being modded you think some one might pick it up and run with it
pfc as well
and your gear boxs is rooted i think i have a mate with a bombed supra 3lt and that happened had to get gear box rebuilt but it goes faster now
james
If it learns has it gone to far past the gear change learning thing
ecu reset will that help i wonder
it is faster when it does not pop isint it?
james
Try resetting the ecu. I found that this helped when I had shit shifts.
how much did it cost u to get a rom tune, i had hyperdrive tune my r33 rb 25 and got 215rwhp, didnt tell me they could do the rom
does anyone know how to extract power from a auto without to much drama's , seems as if everyone that buys one has trouble with this
you can't get a rom on rb25's i don't think.
How would i know if the gearbox is slipping would a shiftkit help solves this a bit?
so you don't think there could be a leak on the turbo or anything Dave?
i wouldn't say so but just want to rule that out as i did have to twist it and i have got silcon patching up one of the intercooler pipes.
There is a torque convert place near Hyperdrive i may go past there today as well see what they recon
I think it's a long shot that rotating the housings has caused a problem, i've done it numerous times myself on that turbo, aswell as my new turbo with no problems.
I'm only speculating that it is the box, it could be alot of things. You could have a cam out a tooth or slipped cam gear, could be a tired engine. The problem is that i'm in sydney and you're in perth and i'm trying to dagnose why the same turbo on the same type of engine is behaving in a completely different way to what it did on mine.
No troubles at all i have in an r33 rb2.5 250rwhp @ 10 psi
Auto
mods
full exhaust
pod
fmic
ebc
you just need shift kit ( insteed of clutch manual eqiv)
my next stage
emanage with ignision harnes
fuel pump and reg and ingectors
cam gear maybe
good wheels and tyers with alot of side wall flex
good 4 a low 13 id hope
james
Edited by Miller the hoon
Standard ECU is restricting u a bit, and u should probly get sum bigger injectors. 232rwhp is heaps low thats like 150rwkw like a standard engine makes. u sure its not 232kw at the rear?
Stock rb20dets dont make anywhere near 150 its more like 100-115
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
