where can i get gauges to fit in a slot where a head unit normally sits as i have an empty spot after installing my new stereo, or can ya get like a plastic holder tray thingy to just put small pieces of paper, a little mobile phone and other miscellaneous items as a small storage type thing, its just i dont want a gaping hole in my centre console :rolleyes: and if you can get this stuff, where and how much ?
have u ever seen the inside of a GTR before? u do realise that u can buy the 3 guage cluster that sits in there... probably expensive unless u can find one second hand at a decent rate. im sure if u hunt around u can find something
I've seen someone on SDU manage to squueze 3 52mm gauges in the centre bit under the stereo.
Looked great. It was a very very tight fit, and I think he had to angle the gauges towards the driver slightly to fit them in!!!!
The problem with getting the GTR center doova is that it goes right up the top where the air con is. It has that corner bit (top right) missing to fit in there, but so does the air con :D
So if you move the air con down, or put the GTR doova under the air con, the middle one will have the corner piece missing as well.....
Another thing about the GTR console is that it takes 42 or 45mm gauges, which are hard to find. And there's no use using the GTR gauges cause it has the 4wd gauge on it which will be usless on a GTS-t :)
J
also jsut wondering,i have a pioneer 6450 head unit that i just installed today and i mounted it with the two standard screw holes on the bracket, and its a good 2 cms in the dash so its ugly at the moment, whats the best way of bringing it forward to fit snugly to the front ?
Scotty - you can get 45mm gauges here
http://www.omorimeter.co.jp/english.html
Don't know if they are any good or not, plus you'll have to mod the plate a little to get them in.
Anyone else know where to get 43mm gauges??
J
Or you could try this:
*3 Gauges on top
*Air vents
*Climate Control
*A/M Single din stereo
*Centre-console-plastic-compartment-holder-thingy-doova-tray-box
*Cig lighter / ash tray...
Just an idea :wave:
ps. the tray fits a mobile / charger / handsfree or small sunnies, but probably not all at once :) [a single din-sized box]
i dont mind the original, its better than any other car i have seen, but until i come across one i like better im sticking with the original, but i know i do need a new boot for my handbrake and possibly even the gear knob as they are pretty ****ed :P
btw just successfully install my two front 6"ers yesterday i did the head unit and the amp in the bootr, now im off to bunnings to get some MDF to raise my 6x9s on the back aprc el shelf, not to mention carpet it, boy o boy this is gunna be a pretty big job :)
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
