  • Replies 157
Posted Images
haha No I wasnt taking the piss "I think" I posted that late in the night so I wasnt thinking.
Anyway Hey Insssain how many ppl now im trying all my friends
Thats cool.
Well sorta if its like AHG then there isnt much signing to do its pritty much give them your licence no. then sign it.
Insurence isnt required as no WA insurence will cover us for Legal racing :S stuped really.
how comically ironic
you put an 'i' in pretty and an 'e' in stupid :)
