Mate that was some awesome burnout, was starting to get really jack of the sh!t performances out there, then you took it up a notch. :)
I *MIGHT* have some on my camera but i can't remember I'll check it out tonight.
Edited by Oosh
that pad is f*kn shithouse. buy the 3rd round i was hitting the pot holes and it was f*kn up my spin. theres no room to swing a cat and they told me if i stand still again i'll get disqualiphyed.
speedway city ownes collinsgrove.
but i hear there are new pads coming up all over the place..
Talemn Bend anyone.
Yes, we decided that the burnout pad really needed to be about 1/3 longer in each direction to swing cars around without fear.
Happy Birthday to my wife as well, who let me go instead of shopping with her and her family on her birthday!!!
mmm so chunky you can carrve it..
close. its the quad cam VG same at the z32's but only single ball bearing turbo. forgies and shot peened rods, stock.
running 10 w/o cooler. coolers coming from japland atm.
Head up to Blackwood Auto and Dyno.
$35 for a power run. :(
My Rb30DET running the stock rb20det turbo where it made 176rwkw at 9psi, which is most definitely slower than how it feels now without a tune running the vg30det turbo.
Mine will spool up to 13psi by 2100rpm (appears to surge or some thing under that) general driving say rolling out of a corner at low rpm and booting it will see 13psi or so at 2500rpm. It appears to pull hard until 5800rpm, all though it does go a lean after 5500rpm. Needs to be tuned.
Edited by Cubes
that van allways puts on a good show.
but after all that i got second in the 6cyl class, beaten by the UC torry cause 3rd round f**ked up.
there were potholes in the pad by the 3rd round. it was a joke. i didn't know what was stopping my spin till after. i thought it was the rear bags were failing but i was hitting the potholes stopping my slide so i was getting stuck up against the armco. and pissed off so stuffed the rest up.
bloody good day thoe. some very quick cars and some... well...
i heard from an offical that the kingswood rocked up with a generator belted up in the passenger seat with an extention cord running to a leafblower set up as a s/c..... :lol:
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
