The last few days I've had ALL the warning lights flash on at night. I've had good oil pressure, plenty of oil, good engine temps, nothing seems to be wrong... It has mainly happened when either trning hard, or accelerating hard. ALL the lights come on, even the spare tyre light and windscreen washer light...
Anyone else had this happen? I'm guessing theres a loose wire somewhere maybe?
https://www.sau.com.au/forums/topic/96447-dr30-dash-warning-lights/
I had this happen the other week, check the wiring from the alternator to the starter motor and make sure that the but is done up tight!! Mine was earthing out on the support bracket for the plenum and causing all my dash lights to stay on!!!!
Yeah i've had 3 alternators go in about 4 months, got one rebuilt and haven't had issues with it yet, but i don't drive it as much anymore so who knows....
No idea what an alternator is worth Adam, go suss some places out ring around easiest way
Yeah pretty sure it is close to one, just have to change the wiring or something..
I got mine rebuilt by s&b auto electricals, Jacobsen cresent, instead of turning right to go to jaustech, turn left and its behind a furniture place up there if he's still there, if not i'll get the addy of my old boy, he's a mate of my dad's so yer....
same thing happend to me on friday night. 5 mins before i got home my alternator stopped charging, the power cable form the alt to starter had fried...replaced the cable and all is sweet now!
  • 1 month later...
It sounds like the regulator is stuffed though. The alternator should be putting out ~14V throughout the rev range. You aren't doing your electrical system (or your battery) any favours by driving it.
I bet your headlights brighten up nicely when you give it a rev, eh? :P
Depending on your alternator, you will either have an internal or an external regulator. From the factory, they had an external regulator (if memory serves).
My l20et's old alternator used to do this. I was told it was the Rectifier by a few auto electricians. I got another alternator for free and thre it on and it solved alot of problems i had with the vehicle.
My lights are dim as hell, I thought it was getting buggerall voltage, thats why I thought the alternator was stuffed
they probably are getting bugger all voltage, but its more likely down to the crappy old switch gear and low amp cable to the headlights in the factory loom. rewire with relays and serious cable.
changing the alternator is a drive way job son, should take about an hour or so, i wouldn't be stuffing around with changing regulators, if you've got a number for the alternator just get a new alternator, and keep the other one for a spare
  • 3 weeks later...
hey so does anyone have any part numbers for replacement alternators.. or spare parts or anything??? mines now cooked for the second time, only got it rebuilt a couple of days ago, and it died within a few hours of driving...? what gives?
to my knowledge it was rebulit with aussie parts from an MR30..
also does anyone have anything lying around that i might be able to buy as a replacement?
cheers.
dave
also does anyone know of any other alternator off a different vechile that happens to have the same connection at the rear, and same bracket mount points.. because if i can id like to install something with an external regulator to enable the ease of service again at a later date.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
