okay my afm is stuffed just i havnt had the money to fix it...
ill be doing a turbo upgrade ome time next year... so ill need a new afm for that!
to fit the z32 afm what do i need to do?
how do u rewire the plug?
and do u need to retune?
thanks
Edited by DriftSquad
https://www.sau.com.au/forums/topic/96546-z32-afm/
$394 brand new from Nengun -- delivered
without plug though
Try the Bosch equivalent, much cheaper - mine were less than $300 ea. No plug though. Have alook at the APEEXi pods which come with the correct size filters to match the AFM's & if you select the correct kit you get the plugs with the kit.
https://www.sau.com.au/forums/topic/96546-z32-afm/#findComment-1756896
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
