R33 GTS-T Auto
Pod
FMIC
EBC
High graph = high setting on EBC
Low graph = low setting on EBC (max 175rwkw or so)
As you can see, the high setting is poor on the lower end.
Does anyone have any suggestions on ways I can solve this issue?
https://www.sau.com.au/forums/topic/96547-analyse-my-dyno-graph/
wink i friend of mine is running a WOLF 3d in his auto as it has the out puts to run the auto (but i'm no fan of the wolf)
SAFC 2 would be my suggesting, not to $$ second hand and in the right hands can be tuned pretty quickly for reasonable results. Plus with fuel prices like they are now it would most likely paid to get it done. Whats your fuel consumption like with the map running 10:1 when i would think 12.5:1 would be much closer to the mark for a light tuned rb.
pete
The PFC also has "outputs to run the auto", no big deal there. The problem is no aftermarket ECU (that I have found) has the shift logic programmed to cut/retard the ignition on gearchanges. I have driven autos with Motec's, Autronics, Wolfs and PFC's and none of them have decent shift quality. They are all very jerky at low throttle openings and have lots of slippage at larger throttle openings. The more power, the worse the slippage. All but one have now had gearbox rebuilds in fairly short intervals.
In the Stagea I have a Jaycar DFA for fuel tuning, a Jaycar IEBC for boost control and an Apexi SITC for ignition tuning. That's a glove box full of piggy backs, but the gearchanges are as good as standard and the gearbox is still alive and kicking.
:P cheers :)
Emanage is better than safc cause you can get it with a ingnision timing
harness
now after that you will need a shif kit
fuel pump reg and injectors
make a box for your pod
hiflow turbo
good for 220rwkw at least on a good turn not maxed out
james
Wink - easily said, as others have but you seem to be missing the point.
PowerFC - dont bother, its possible, but with major side affects you dont want
S-AFC - is what you want and will fix your problem with a little tuning
Wink also is that with your foot flat on the floor to get full throtal
when mine was at 12psi it would pop
i have set it to 10 and now my power band is heaps better
stock ecu cant handle much more than that nether can the turbo
no mention of an exhaust system
james
I forgot to mention the car is also running a 3" turbo back but only stock cat.
It seems general consensus is that a SAFC is the way to go.
However miller brings up the GReddy E-Manage.
The E-Manage costs around the same as a SAFC so can someone give me a quick comparo of the features/differences.
In the end, E-Manage (with Ignition harness) vs SAFC + ITC.
Thank you all for your informative input. Appreciate it! :(
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
