I own a R33 and unfortuantly i can tell you that all my bass is trapped in the F#$%in boot.
There is a 12inch sub in there i swear. Its just the metal plate that separates the boot and the back seats blocks my bass.
It used to sound good in my previous car. 8-(
Anyone got ideas on removing it or cutting holes in it to free the bass...
Thanks. :uh-huh:
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/
if your sub box is ported then it won't sound as good as a sealed enclosure in your car.
at the moment i have an old pioneer 10" free-air in a sealed box (i know, i know, it's not designed for a box...) and it actually sounds a lot better than i thought it would.
which way is the sub facing? try facing it into the rear corners of the boot.
also make sure your boot is sealed properly.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-150456
Hmm, I suspect a better sub/subs and amp would make a huge difference.
I have 2xSoundstream Rubicon 300W with 1x600w earthquake amp.
There in the boot of the crx, which is in no way connected to the insided of the car.
More bass than you can poke a stick at....
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-152047
you wouldn't want to that plate contributes to some of the structural stability of your car.
besides... bass should pass thru the metal plate with relative ease as its not a dampening material.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-153459
My mate just put a sub in his and found that removing the factory false wall that hides battery, it mabe a very noticable difference. He is fabricating a new cover.
Me personally i beleive in speed. SKYLINES are performance cars not BOOM boxes. And before you ask, I have decked out my company van (owned by the company i work for, but in my care 24/7) with a decents audio system, including a 12 inch Rockford Fosgate sub powered by a PUNCH series R.F. amp.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-153680
No need to upgrade my system. Its the pump.
It's just it sounded better in my Hot Hatch than it does in my GTS, I guess thats to be expected though.
Ive spent over 4k on it and its all Alpine with a 12" Kiker and 2 x Big Kenwood Amps so i dont think upgrading is the problem.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-155183
Ah ok.
Still, with that type of set up, it baffles me how you can ask where the bass is...:lol:
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-155293
It's got me farked where your bass has gone. I have a Fusion fpw-1500 15" run by a Rockford Fosgate 250m2 monoblock amp, also in an R33. There sure as hell isn't any problems with bass with that, and it's in a ported box.
The Tool
Dunno what you mean by "a ported box won't sound as good in your car". Mine sounds fine, heaps better than my old sealed box, and is absolutely cranks with the low notes.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-157646
I put my old amp and sub into my 32 and was pleasently surprised at how well the sound travels through the metal sheet behind the chair. Not quite as good as my 180sx though but the equipment has aged and had a hard life since then so it may not all be the car. No way I would go to the effort of cutting out holes when it sounds perfectly fine facing the back of the car. Cutting holes or removing it alltogether is also illegal too as you are removing too much structural integrety of the car.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-163861
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
