Yeap, you definately need too see how much boost your running, then adjust the controller from there :(
Glad your happy with the install... Thats was the quickest install so far..
Try find the original charcoal canister set up, will get rid of the mitsubishi charcoal can, and stop your weird idle problems...
Siddr20 has the same charcoal can as you, and makes it idle funny too...
where do you reckon i can chase one of them up ?? ill try to get one asap. But the car is running smooth now no problems at all.. ohh and i brought the T piece and installed to boost gauge was running 14 psi spiking to 15 unless my boost gauge is reading wrong... no wonder my car smelt like it was burning hahahha
Turn down the bleeder... It prob runs harder now as your boost controller wasnt hooked up right
what happend to the rest of the case if you only drank like 9 cans? also FTR a 700ml bottle of beam, a couple of big bottles of coke and a kettle is the way to go.
Im not sure????????? My buddy had a few cans. Im not a big drinker, i only drink every month or 2 months so 10 cans and im usually a bit under the weather........
  • 2 months later...
Mr g,
Will hopefully be getting a fmic when funds allow and will probably be heading your way for an install. In you experiences which intercooler is easiest to fit out of the hybrid or just jap kits for an r32 gtst? Or for that matter is either a better quality?
^^^ In my opinion, the hybrid and the justjap kits do the same job at the end of the day.
I did an install for Gengis yesterday at his work (got shifty looks by some), and he bought the justjap kit... If you refer to his FMIC installed thread, he quotes that the car feels more powerful at the top end from the cooler, however you get abit less lag from the start. This is due to the extra volume you are trying to fill up when boosting, hence some guys tend to wind up the boost another PSI or so.
For the GTST, either the hybrid or justjap one is the same amount of time/ease to install. :)
By the way, you dont have to head out my way, I come out to you providing your in Sydney :D
Thanks for your 2cents.
ill get back to you when and if the budget allows.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
