  • Replies 83
^^^hey man wat kit iss on that 32, its real nice by the way :D ^^^
The kit is a Aeromaster Type 1 (which is remarkably similar to a vertex, but not quite). Front back n sides. I bought the original from Japan, which Aresspeed got off me to copy. Ended up keeping it for well over a year and finally fitted my original onto some demo car of theirs and gave me two copies for my trouble. Apparently they're bankrupt now, so not much I can do about it.
haha... hope it's not mate!! Got written off about a month ago!!  :lol:
lol yeah I know, well not written off, it didn't even need a viv check. once striped the damage was far less than it looked, wasn't hard to fix.
Edited by wal
  • 2 months later...
  • 2 months later...
