dyno tuners
I suggest a search thru some of the old threads might work.
This has been done ( to death ) before with some fairly heated discussions ensuing.
And as Paul said do not bag anybody out about what sort of job they have done on your car. It will only lead to the thread being locked so if any body wants to know , they can PM ( also as paul said )
Cheers
( trying to be neutral )
Ken
https://www.sau.com.au/forums/topic/9794-dyno-tuners/#findComment-151914
fabiansgtr/Steve-SST,
We were not saying that your were intentionally having a go at anyone, just reminding everyone that even if they have bad experiences that the forum is not an appropriate place to air them, that is for Private Mail (PM).
We want to keep as much politics out of the forum as possible.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9794-dyno-tuners/#findComment-152723
