Just wondering what sort of speeds a standard r32 GTR with the standard gearbox ratio's will let you get up to. Thats of course if you get rid of the fuel cut. I was thinking 260 or 270. Is that close to the mark when hitting redline in 5th??
I have the 320 dash and just wouldn't mind knowing. :lol:
Cheers fellas
https://www.sau.com.au/forums/topic/97971-what-speeds-can-you-get-to/
I've had my gtr to 270 on my speedo, probably not very accurate tho.. but it was no where near the redline in 5th. was still pulling but ran out of track.
top of 3rd is around 180, top of 4th is around 240 ... will have to get hte gps out next time i have passenger lap to see how true it is
according to reference.com the top speed is 257 km/h
there you go theres a official number
and im guessing reference.com is a trustworthy source....??
and from when i was doing a top speed run in my GTR from speed and revs i was doing i believe thats right on the money of the gearing (for a R32 dont know if others have different gearing)
RellikZephyr
   Cheers fellas
Gearing for an R32 GT-R is as follows (all in km/h per 1000rpm)
1st 8.9
2nd 14.8
3rd 21.9
4th 28.5
5th 40
There is an old Wheels magazine around with a test which produced a terminal velocity for a stock GT-R at around 250km/h (from memory).
But don't try it at home, kids.
Edited by djr81
  • 4 weeks later...
FTR: I have just watched an R32 GTR torrent file, I think its an old BMI Video from 1989, they have incar footage of standard R32 GTR around the Nurburgring, speedo was hitting 240kmh.
Then later tested over the QTR = 13.32
Then on a Banked High speed circuit = 247kmh
My Speed limiter cuts in at 181kmh as I found out at the drags :P which is basically top of 3rd in a GTR.
Can anyone remember which wire it is on the ECU you cut to disable the speed limiter?
Or point me in the direction of a thread that does......
r33 its gts-t its 280
280km/h in a GTS-T? :blink: For a stocker? :lol: I seriously doubt that! :P
(EDIT: Or do you mean it is geared for 280km/h? In that case it is more beleivable and you are forgiven with my apologies!)
On the serious side, I've heard around 250km/h mark is about right for the R32 GTR - the car may be geared for more (maybe 260-280km/h), but I don't think the stock car can pull redline in fifth.
Edited by Big Rizza
define STOCK R32 GTR
mines got 3" turbo back straight thru exhaust, apexi pods, boost restrictor removed
and it was still pullin strong at 6k in fifth
i would have no doubt i could hit the fifth gear redline
but mine may not be considered STOCK
RellikZephyr
1st          8.9
2nd          14.8
3rd          21.9
4th          28.5
5th          40
good stuff - seems to work out spot on with my R32 GTR which from the speedo roughly gives 120kph in 2nd, 180 in 3rd, shifting at 8000rpm. Looks like its actually 118.4 and 175.2. Close enough for me. I think I hit about 220kph going into the Caltex Chase at Bathurst on the run where I got a tow behind a sport sedan down the straight and didn't lift through the kink - but its hard to get more than a quick glance at the speedo in those circumstances! Plus its a 300kph speedo, so its hard to be too accurate with the lines being quite close together at the best of times, let alone at over 200 going into the Chase right up the arse of a sport sedan... :unsure:
I've also heard the top speed for a standard R32 is 250kph - I think I read that in a Julian Edgar Zoom article when he first got that Aus-delivered GTR he crashed :lol: Not sure what his source was. As you can see from djr81's specs above, 5th is a real overdrive, so it wouldn't surprise me that it isn't able to put on too much speed in 5th.
RellikZephyr
Sorry to hijack but u say u have removed the boost restrictor. what exactly is this and is it easy to do? can it be done on an R33 GTR
RellikZephyr
You dont have a hope in hell of getting anywhere near the redline with those mods . The 32 + 33 GTR is geared to so about 320 if you could get to the cutout but unless you have a very powerfull engine you wont go anywhere near .
A stock 32 will do about 240kmh a stock 33 a little more and a 34 a bit more still
If you could get to the cut out on the 34 you will be doing over 340kmh in 6th , but for a stock car about 255-260 is all you will do .
sorry mate i didnt remove restrictor myself so i cant help you with that, from what i understand its not that hard also i think R33 is electronically boost controlled so its a little different (but not sure i own a 32 so i know the 32, not 33 sorry)
cant really say i agree with that, but i will try another run when i get my car back (fixing idle problem), rather than me arguing yes and you arguing no i will prove (or disprove) what really happens
RellikZephyr
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
