  • Replies 40
Doodz it might be a belt tensioner.Have you recently installed a heavy duty clutch?
definetly not the clutch either.
I would put money on it being a sticky lifter, especially since he changed the oil last week and with a different type :)
I would put money on it being a sticky lifter, especially since he changed the oil last week and with a different type :(
My car is doing the same thing and was told it might be the lifters but someone else said its the injectors because its an RB26, dunno which is right but i want that sound not so loud, and its on idle aswell :)
My car is doing the same thing and was told it might be the lifters but someone else said its the injectors because its an RB26, dunno which is right but i want that sound not so loud, and its on idle aswell :(
The injectors are always noisy on every skyline i have heard, but on GTRs (especially older ones) the head does get a bit noisy, they dont have hydraulic lifters which when working properly are quiet, the head in a gtr will just be a bit noisy all the time with age
I would put money on it being a sticky lifter, especially since he changed the oil last week and with a different type :P
that happened to my car on friday night too ..
hardcore knocking sound.. freaked out.
now the sound is gone ;o
My car isnt THAT old.. its a '94 model (the last year they were made :P ) .. it was coming from the front of the engine/fuel rail ..
if i was to upgrade injectors would it be not so noisy? Because it sort of worries me.
My car isnt THAT old.. its a '94 model (the last year they were made :) ) .. it was coming from the front of the engine/fuel rail ..
if it does make them quieter, good excuse to upgrade them :)
ok update...
mechanic found two problems that might be causing the noise..
water pump was loose, banging against itself.
and the ac tension bearing pulley was sqeeking
got both parts at justjap $183, but i bargins and got it to 180$ LOL. I think this was SAU price too..
My car isnt THAT old.. its a '94 model (the last year they were made :( ) .. it was coming from the front of the engine/fuel rail ..
well by old i mean say more than 5 years old <_<
New injectors are quieter, but wont be forever! I wouldnt worry about it, just make sure they are clean and they should be fine, they are all a bit noisy!
dood go and get a long screw driver and listen to ur engine, this happen to all skyline...........so dont worry.......try using motul 8100excess.......and it would go away.....the lifter is tapping the top so it ok...
if u rev ur engine up and it tick,tapping...then it could be ur cam bearing.........
its all about the oil.
what viscosity is the motul oil your using?
25lifters can be very sensitive to changes in iol thickness. the oil feed to the head can also block up :blink:
undo the oil cap and see how much oil is getting up there.:
i spose the easiest way is to chech it with a friend with the same engine
ps. there should be enough oil to splash evry ware with the oil cap off.(just the odd splash out of the oil cap with a continuase swirl of oil around the cam lobes,if thats any help
cheeres
ok update...
So has the noise gone away or is it quieter.. Please give an update as i wanna know whats wrong with mine :(
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
