just wondering what people would recommend i do to my GTR before hitting the track (to keep it alive)
i have a Oil Catch Can and will be putting a sump baffle kit and oil cooler on
have just changed gearbox over (stoopid syncros) and turbos (cause of shaft play, but still stockers) have an EBC and will run no more than 1.0 Bar
i have a twin plate clutch and triple core radiator
other than Pads, Oil and Oil Filter what do you recommend i do?
keep in mind it is a daily driver 90% of the time and only really a weekend warrior
Thanks
RellikZephyr
EDIT: Oh yes and i will be getting a HICAS locker kit too
Edited by RellikZephyr
https://www.sau.com.au/forums/topic/98308-what-should-i-do-to-my-gtr/
  • Replies 105
that's all you need. just make sure you have fresh oil in it and most importantly bleed the brakes properly (flush plenty of fluid through) and use good fluid.
my plan was to change oil prob every 2nd track depending on how much driving ive done between track days if monthly then prob every track day
should i do this with the brake fluid as well??
RellikZephyr
if you are trying hard you will probably need to do brake fluid before each track day. once it boils you will loose pedal feel and in my exerpience it doesn't come back untill you bleed again. i would use around 1 and a half litres for the initial flush and bleed and then providing you don't completely boil it on the first trackday use about 1 litre the next time. try and stick to the same fluid or else you are back to square 1 (needing to flush out all the old fluid). nothing worse than loosing pedal due to cooked fluid halfway through a track day then having to sit the rest out, or try and bleed it there, or put around with no brakes :)
I use MOTUL RBF 600 which is a dot 4 fluid with a high (600 degree) boiling point. It costs about $25 for 500ml which is enough for a change. Your pads will give up before the fluid will. Have agood think about your pads too. The rears will be fine, but the fronts will hate you for what you are doing.
Just make sure you let everything cool down before you go out again....
Oh, yeah - you will make a right mess of your tyres on the track too.
I reckon you've got it about right. Anything you're willing to do to help the oil system, do it. I'll be fitting an oil cooler before I do any multi-lap supersprints next year.
I don't know why everyone says to remove the HICAS, mine is fine on the track with HICAS connected. The only arguments I've heard against it are that it makes the car unpredictable, which is utter rubbish. And that it causes understeer, which in my experience is also BS. The reasons a serious race car would do away with it are:
1) weight saving
2) reduced complexity (one thing less to go wrong)
3) its an unnecesary system, and everything unnecesary goes in a race car (where rules allow).
for a street car with the odd track day, I wouldn't worry about it. I'm not saying it doesn't have any benefits to handling, but there are certainly other areas in the suspension that will make huge improvements to lap times before worrying about the HICAS.
Thanks for all the replies people
next question what clubs are out there in Melbourne
and are any of them CAMS affiliated
ive seen that team wang one i like the slogan :)
also i know NDSOC is CAMS affiliated
so anyone know anyone i should get in touch with?
Thanks
RellikZephyr
SAU VIC. it's cams affiliated i believe.
DJR81. mate i don't believe that 500ml is enough to do a full flush on a 32 GTR. that is just scraping the surface. I have cooked fluid plenty of times before the pads gave in, though a couple of times they tend to give in together (pads starts to go, need more/longer braking, heat goes up, fluid boils). I also use RB600 and can still cook it before cooking a moderate track pad (700degree pad). also RBF600 is a 312 degree C fluid.
how many laps are you doing in one session? and how many sessions to a day?
1) weight saving
If you don't yet have a cooler it pays to keep an eye on the oil temp gauge. Mostly your brakes start fading before the oil gets too hot.
I have had the HICAS connected on the track & also a lock kit installed. Either way the car is driveable. The difference I found was mostly a confidence thing. Having the rear opposite phase steer on turn in freaked me out a little & I did find that with it removed the car felt more predictable. So it is a preference thing. As for understeer, well I found it split into two halves. On the turn in phase the HICAS reduced the understeer, but on corner exit it increased it. Just like it is supposed to. Anyway the Nissan blokes knew a thing or two about car set up - so you can be confident you will have bundles of fun on the track with a stock suspension set up - HICAS & all.
As for licenses - go to the CAMS web site & find yourself the paper work for a level 2S. In conjunction with a club membership this is pretty much all you need. Cost is (from memory) less than $100 a year.
I use RBF600 all the time, so I find 500ml enough. Each to there own, another $25 shouldn't kill anyone. Yeah the 600 degrees is in fahrenheit, not celcius, but still better than dot 5 fluids.
We usually are restricted to three laps at a go (Plus warmup lap & cool down) and at the end of the main straight at Wanneroo my brakes are feeling the pain on the last lap. Usually the third flyer is slower than the other two because the brake friction coefficient is heading south. Having said that I only use RB74 pad's at the moment on stock calipers/rotors.
Speedevent series gives us four sets of laps plus a warmup & if you are lucky a discretionary run in the arvo.
are you saying that HICAS steers opposite to the front initally and then with it? where did you get that explanation of the HICAS system? any more details like how long it holds the counter phase steering before changing, or under what conditions it does this, or is it simply all the time?
Precisely. The explanation came from the original R32 GT-R test drives done by both Wheels & by Car magazine. The description in Wheels is as follows:
"Nissan's sophisticated Super HICAS system works in two distinct steps; initially in reverse phase (with the rear wheels turning through a small arc in the opposite direction to the front) before moving to the parallel phase."
Car was a bitmore effusive:
"The rear wheels counter-steer to help the Skyline turn into the corner, and then steer in the same direction as the fronts, to help stability.... At high speed, though, the maximum movement is approximately 0.3 degrees"
Unfortunately neither nominate a speed at which the system works/stops working. From what I understand it changes phases, ie from counter steer to same phase when you get on the accelerator.
The reason that some people say it makes the car's handling more unpredicatble is that when you turn the car into a corner you need to differentiate between the HICAS working and the back end losing grip & starting to slide. Sometimes that is not so easy. Disabling the HICAS means when you feel the back end getting loose you are running out of grip. Having said that everything it does after turn in, in my humble opinion, is all good.
Thanks Ferni
unfortunately i am going back to queensland on sunday/monday to visit family for chrissy so thanks anyway but i cant
i do remember reading something about a meeting on the sunday (20th) and i was thinking about going to that depending on wether im leaving the sunday or the monday. so i might see you there
RellikZephyr
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
