i been searching around forums and you all know im new here and new to skylines and turbos,could anyone explain or direct me to a thread that explains both what boost is how it works, and psi i read in a number of threads ppl changing psi etc really wanna know what it is and how boost gauges work sorry if i sound like a newbie but id really like to know thnx
https://www.sau.com.au/forums/topic/98417-question/
'boost' is what a turbo creates.
a 'normal' engine, ie one without a turbo works by sucking air in, mixing it with fuel, igniting it and using the explosion to turn the crank, thus creating power.
so say you had a 5.7L V8, it would at any time have 5.7L of air/fuel in it to be ignited, and obviously more air/fuel will cause a bigger explosion, and thus create more power.
now, a turbo engine works by the turbo 'forcing' air into the engine, mixing it with fuel, igniting it and using the explosion to turn the crank, again creating power.
this is why you see alot of the turbo engines are alot smaller, ie the 2.0, 2.5, and 2.6L of the skyline, yet they can still pump out the same power as a big V6, or even a V8. say you have a RB25DET, 2.5L turbo. now whilst the turbo hasnt kicked in(ie low revs) the engine will have approx. 2.5L of air/fuel in it to ignite, and create power with, *but* once that turbo kicks in, say you are running 1 bar(14.7psi of boost, ill explain this in a bit) you are effectively pushing twice the amount of air into the engine, so that 2.5L engine is taking in as much as a say a 5L engine.
now onto 'psi', the word stands for pounds per square inch.
a normal, un-turboed engine runs at negative psi, meaning that the engine is *sucking* in air.
however a turbo engine runs *positive* psi, meaning that air is being forced into the engine, and the higher the psi, the more pressure, or 'boost' your turbo is creating.
say you had again 2 RB25DET's this time... engine A running 7.5psi of boost, and engine B running 15psi of boost.
now engine A will have approx. 3.75L of air/fuel in it at any time, whereas engine B will have approx 5L of of air/fuel in it at any time.. so the more psi your turbo makes, the more boost created, making your engine effectively larger, and creating more power.
now i better get an A for this essay... :P
https://www.sau.com.au/forums/topic/98417-question/#findComment-1788456
if its got an aftermarket boost gauge, it should show you what psi/kpa it hits (1000kpa == 14.7psi) or if it has just the stock boost gauge in the dash, work off this... the +7 at the top is about 14.7psi, and yours will probably hit around the middle mark, so ~7-10psi
:P
https://www.sau.com.au/forums/topic/98417-question/#findComment-1788490
thnx alot mitchy that was very helpfull i should be getting m ycar in around 2 weeks how do u know wat psi your turbo is on or wateva sorry if im saying it wrong
hey Sammie,
i through i add my 2cents and see if i can help you :D
The stock turbo has something on it called an Actuator, this controlls boost on your turbo. When your car is stock the turbo should run around 5-6psi. But if you start to mod your skyline like putting an airfilter or exhuast the boost will slowly go up by abit, so you may be running 9-10psi.
Thats why its always good to get an aftermarket boost gauge when you you start modding you car, as its good to know where your boost levels are at.
also another tip more boost doesnt always mean more power, if you boost your turbo out of its Effectiveness range (for example the stock turbo max lvl of boost is around 12psi) you will not make anymore power.
and good luck with the new car :(
-Michael :)
https://www.sau.com.au/forums/topic/98417-question/#findComment-1788660
some very important facts about turbocharging also to note:
more psi or more boost means more heat
more psi or more boost doesnt always mean more power
compressing the air intake (or making boost) heats up the air, thus a need for an intercooler
an intercooler takes the heat charge off the air intake after it is compress, most people think it cools the engine down.
a boost controller can be a wastegate (external) or internal wastegate flat controlled by an actuator
boost is a resistance to air, if you add more boost you generally make more power upto a certain limit which will be the limit of compressor wheel, once you reach this limit any more psi over it generally just adds stacks more heat and it makes no more power
a bigger a/r turbocharger will come on later in the rpm range but make more power top end.
a smaller a/r turbocharger will come on earilier in the rpm range but make less power in top end.
a/r is a measurement for area / radius. a stock r33 turbocharger (gtst model) is around 0.50a/r
cars that run a twin turbo setup generally use two smaller a/r turbochargers and a single turbo car generally runs a larger single unit
pressure and volume are two different things
if one car runs 12psi and another runs 9psi this means absolutely nothing other than the amount of pressure they run
the less boost you run the better, the less friction, the less heat, the less lag and stress. make the required power at the least amount of boost possible
https://www.sau.com.au/forums/topic/98417-question/#findComment-1788697
heyas, since we're on the topic....I've recently bought a 33 GTS-T, everything stock. I'm surprised to find that when the needle sits half way between +7 and 0 it means around 7-10 psi....I originally thought that it would mean 3-4 psi. If this is true, then I rekon my skyline ain't that quick :)
https://www.sau.com.au/forums/topic/98417-question/#findComment-1789522
EDIT: I'm a dumbass. Sorry brain fry
No halfway should mean 7psi. 7mmHg is about 1bar (14.7psi).
Stock should be about 5psi till 4500rpm then go up to 7psi.
Edited by shif_tea
https://www.sau.com.au/forums/topic/98417-question/#findComment-1792489
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
