I would be, although it's going to be very embarassing.
Is this a definite thing or a maybe? I'm not supposed to be driving, so I'll have to try and find someone to drive my car for me.
i guess i can tow your car :lol:
https://www.sau.com.au/forums/topic/98590-just-a-thought/#findComment-1794993
Time: 1:00pm
Cost: $50 per car
Prize: Free service, Motul Oils, Alpine Speakers
The dyno will be under a shoot out mode, which means no cheating will be happening.
BBQ will be happening and all cars are welcome.
No tuning will be happening.
Cheers
https://www.sau.com.au/forums/topic/98590-just-a-thought/#findComment-1795105
