Hey guys and girls, i have just bought a car and need some help on mods and compliance. The car is a 1989 Nissan Skyline R32 GTS-t 4door.
These are of the car right now in Japan
This is a quick chop i what i would like it to look like
the mods done in the chop are
Removed Rear Spoiler: whats involved in doing this, cost?
Rims: looking at 5 spoke around 17inch, which are either white or can be painted white. whats involved in painting rims? is it something is shud do or shud i get pro, powder-coat etc etc???
Suspension: i would be looking to lower the car 40mm at the front and 50mm at the rear(going by pictures, will have better look when the car gets here), whats a good cheap option? looking for increased handling aswell as look.
Bonnet trim: i have looked at cutting the little lip on the bonnet that hangs down between the lights. it would then be filled with black mesh. method??
as for Compliance: is it worth doin it myself, whats the cost difference on average? thanks.
https://www.sau.com.au/forums/topic/98719-just-bought-an-r32/
This will give you a few ideas about Compliancing.
http://www.skylinesaustralia.com/forums/in...showtopic=41327
The beat way to go about rims is to buy white ones or get second hand rims (cause they are cheaper) and get them coated in white enamel, as it sets hard, but I am not too sure about coating Alloy but just ask your local paint shop they should be able to help.
cheers
Chris
yeh thanks, i think i might be covered on the compliance, i have got a quote for around 700 with RWC at a shop. sorry but some of the Qs have already been covered in the NS.com thread.
yeh do u know what size stockies are, 16's?? might get them powdered, or just find some real cheap 17 5spoke alloys and powder them.
I've seen some GTS-T bonnets cut to accommodate a GTR grill, and they've all looked pretty dodgy. If you're keen on the idea, cut the whole inner section out, and weld in a new plate, so it all looks neat. :)
Adrian.
Depends on how neat you'd want it to look. Very low cost if you just plug up the holes with some silver watertight plastics plug and up to $300 to get the holes welded up and boot resprayed.
I suggest you get them white to start of with and failing that, get a pro to do it. Be warned white multispoke rims require alot of dedication to keep clean.
Get some springs that'll lower the car.
I think you'd be better off getting a GTR bonnet.
Edited by Wink
with the bonnet, i recently done just what you want. cut the lip off with an angel grinder, covered the exposed metal so it wouldnt rust, and cover with a gtr lip piece.
at the jap wreckers here it was $350 for a gtr bonnet which had a dint and huge scratched dint in it.
my $100 gts bonnet in perfect condition with lip grind off works just as well.
pic can be found here
http://members.optusnet.com.au/damage/boos...ll_Sv402956.jpg
That actually looks pretty good. Can't even tell its a GTSt bonnet
yeh just another quick Q, i was looking at a list of mods recomended by Dr Drift(from ns.com maybe on here aswell) and he rekons to go exhaust and fuel pump (bosch 040) first, and then intercooler after those 2.
just wondering about the fuel pump, he recomended about 400 dollars new, i have seen a few used for round 200, i beleive these pumps also need mounts. and my question is if these pumps dont come with mounts or anything but the pump, what other costs are involved, mounts etc? and will i need to get it put in or can it be done by someone of average maechanical skill.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
