hey guys, ive got a r33 gtst with 200rwkw. ive put a xtreme 9 puk cushioned ceramic clutch in less than a month ago and ive just been kind of taking it easy for the first couple of weeks and today ( a pretty hot day 35+ degrees could have something to do with it but still shouldnt happen) i gave a bit of a squirt and the revs flew up and the car didnt move.
I also notice that the catching point on the clutch was abit higher than normal, i thought this was unusual but just tried to get used to it. is it normal for it to be a bit high?
any help or experiences would be greatly appreciated. thanks.
https://www.sau.com.au/forums/topic/99190-clutch-problem-plz-help/
7yphon - when does yours make a noise? i can hear a sound when the car is still and i engage and disengage the clutch but i think thats about it.
wrxhoon - there is very little free play compared to my old clutch and other cars ive driven. its funny i think the clutch is more vulnerable to slip when the weather is hotter, i drove it 2 minutes ago and the temperature is much lower than before and its not slipping the way it was before.
thanks heaps for the help fellas. would it be hard for me to adjust it myself?
I'd take it back and ask...no demand a new clutch be fitted and adjusted correctly. Reason being if it's been slipping (due to a poor install/adjustment) it's now worn more than it should be under normal operation and I wouldn't find that acceptable nor should you.
  • 1 month later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
