all you need to do is connect that nylon piece of pipe (usually supplied with guage) to a vacuum line coming out of the inlet manifold.
then connect the backlight wire up to a dash light wire + connect the earth wire to a ground point. then it should work.
hope that makes sense. but yeah, as kym said check the tutorial section too. :D
https://www.sau.com.au/forums/topic/99232-boost-gauge/#findComment-1807543
where's the inlet manifold?
Vange,
I don't want this to sound mean, but if you are asking that question, it's probably a job better left for someone else. I'm sure one of the guys here would give you a hand and it might cost you a beer!
Merry Christmas,
chops
https://www.sau.com.au/forums/topic/99232-boost-gauge/#findComment-1812450
