"what i am selling contact details on where to get the cheapest  apexi power fc and geniune hand controler,"
Doesnt even look like he is selling an item, but a contact phone number for $200 :|
yea i agree 200 for contact details lol ....
"You can by these direct from me to suit your car for $1550 delivered any where in australia, or alternativly I will sell you the manufactuars address and phone number which is located in sydney who brings them into australia for $1000 delivered which includeds a 12month warranty,"
The above explains a higher price but still it looks too dodgy for me.
I had ebay close the auction because i saw it the other day and noticed how very misleading it was.
This is the response ebay sent me:
"Thank you for your email. My name is Trenton and I appreciate the
opportunity to be of assistance.
The item you have reported has been ended by eBay. "
Fair enough - if they have information to sell then sell it, but they cant mislead people the way they are. Putting pictures of the power FC and the full specifications of the unit is a joke - if your prepaired to pay $150+ for some dudes information in order to buy multiple power FC's you should already know exactly what they look like and exactly what they do.
Rant over.
And if you notice, he's made the writting smaller which *almost* informs the buyer that they arent getting shit.
Funny thing i just noticed is he bought a set of those replacement hand brake and gear boots for an R33.. so he is a fellow skyliner...
I bet he's on the forums too... anyone know a Heath who owns a skyline?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
