Morning all,
I am currently up to the stage of modding were i need/want more boost. i have a turbo back zorst, pod, Greddy FMIC and BOV.
Ive checked out the Power FC's and they look like a tidy unit capable of almost anything. Would i be better just buying an APEXi boost controller for $600 rather than the Power FC for $1000?? would it be worth the extra $$'s for the added features that it offers?
Im not wanting to turn this into a full blown drag car, but i will probly mod further into next year.
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/
  • Replies 63
Absolutely dude... buying a boost controller limits you to what you can do. Yeah sure you'll have boost on tap but you can't play around with the vital things which a Power FC will allow you to do.
Save your penny's and get the FC. They are a plug and play unit and have 101 benefits over a run of the mill boost contoller.
Especially if you are looking to mod further, because the FC will allow you to change things like your and air/fuel ratios etc vital when putting more fast bits on your car.
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1820269
The AVC-R wont give you anything near what the PowerFC will.
Just buy the boost controller add-on for the PFC, only a few hundred more.
I thought that i would be able to dial up the boost from in the car with just the Power FC. Im assuming that the Apexi AVC-R boost controller allows this option on its own but nothing else. I'll check out some prices on the add-on. I was hoping to have it all for around the $1100 mark roughly.
If i was to do no more mods to the car after this would the PFC stil be the better way to go? Would the extras stil be a benefit to me?
Edited by GTS4dood
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1820486
The PowerFC is an ECU
not a boost controller. You need to purchase the Boost Contol solenoid etc in additoon to the PowerFC to make the PowerFC able to control boost
this is covered in the sticky thread in this section if im not mistaken
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1820590
Don't bother with the Apexi boost soleniod kit, the factory one works fine. Just buy a power FC and get someone who knows what they are doing to tune it. Put the few hundred you'll save into dyno time.
Regards
Andrew
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1825779
BBGTR, The RB20DET's run a basic wastegate setup, so an boost controller of some time is required.
Buy the PFC then redrill the holes on the wastegate bracket so that it becomes adjustable. :) Not so much redrill but elong. If you have the cash go the pfc boost controller from nengun.
They are fairly cheap considering its a self learning boost controller. Unlike the Archaic adjust a duty cycle and gain type ebc. The self learning ebc's constantly adjust duty cycle to obtain the target boost pressure.
Edited by Cubes
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1825942
I've always wondered why they GTR's need to run an elec bleed system when they don't have a 2 stage boost like the R33's do.
Whats the 32 GTR's base boost pressure if you were to bypass the solanoid and run it straight off the actuator?
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1826292
I'd just be buying an adjustable actuator and set the preload so you can run 13psi or so. Shouldn't cost more than 250. The r32 dosen't have the aggresive rich and retard strategy that the 33 has so you will make some decent gains from this.
Then save and get the power fc if you want to go further in the future.
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1826326
About 7-8 PSI I think - like most factory springs.
Regards
Andrew
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1826347
Ideally i want to be able to dial up the boost from inside the car. If i was to buy an adjustable boost controller and then later add the PowerFC, i wouldnt be able to use the hand controller for it?? unless is was the apexi boost solenoid that i put on initially??
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1827502
Being able to adjust boost on the fly is a novelty.
The RB20DET isn't exactly a boost monster where a slight flick of the accelerator instantly see's all its boost.
Even with the rb30det and a small motor its easy to regulate the amount of boost I make.
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1827510
after 3 days and the novelty of being able to change your boost wares off.. i doubt your gonna be playing with it much :P
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1827524
I think you're getting confused.
A boost controller is seperate from a ECU. The pfc is a stand alone aftermarket ECU.. which happens to be able to plug into a hand controller.
A boost controller will just change your boost..
So.. it depends what you want to do - retune the car or up the boost.
The PFC -can- control a boost controller solenoid, so in this sense it can work like a boost controller... but they are really 2 different things.
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1827559
an adjustable boost controller is only good for a factory ecu, if you want high power or low power..
but I'd run high all the time and get a powerfc and tune it to it, ebcause if you tune any ECU to a certian boost, and you lower the boost for a "low mode" you'll f**k all of your tune up cause its tuned for higher boost..
Easiest way to do it, is get the powerfc boost control kit to control spikes, spool, etc etc and level your boost, and then use your foot to control boost...
Less throttle means less boost..... If you can't do that, then you're a danger on the road and you should sell your car and buy a push bike..........
Edited by The Mafia
https://www.sau.com.au/forums/topic/99916-apexi-power-fc/#findComment-1828401
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
