V36 370gt Firmware Update
Lads, after reading few threads (in SAU and some from infinity US forums) it appears that I have the same issue on my VQ37VHR V36 7 Speed Auto (Built Dec 2008);
1. VVEL Cam noise ticking/knocking on idle after driving (the noise dissapears after I restart the car as the VVEL solenoid resets)
2. Bucking/ sometimes harsh un-firm shifting
From the suggested, both of these issues can be fixed with firmware update but I need to get in touch with Nissan techline before heading to one of the GTR dealerships in Perth otherwise they would be totally clueless.
The question, how do I get in touch (email/phone) with Nissan techline?? and those who did the firmware update, how much did it cost??
Thanks in advanced.
Edited by kliono
As far as I am aware there is not a single Nissan stealership in Australia that does not ABSOLUTELY HATE grey imports, and as far as I am aware they won't touch them with a 100 foot pole. Certainly all of the Nissan dealerships in Adelaide won't touch a V35.
Shit...that is no good. However, AWSAM's post showed that there is some hope. As long as you approached techline first prior heading out to stealerships. So I was hoping;
1. Contact techline and notify the problems
2. Techline contacts dealership for the remote firmware update
3. Book in for it
4. Come in and pay megabucks to fix their f**k up
Shit...that is no good. However, AWSAM's post showed that there is some hope. As long as you approached techline first prior heading out to stealerships. So I was hoping; 1. Contact techline and notify the problems 2. Techline contacts dealership for the remote firmware update 3. Book in for it 4. Come in and pay megabucks to fix their f**k up
keep us updated how u go with it mate :)
No where now hahah. Don't even know how to contact the tech-line. Called the dealer and asked for tech line number they were like 'huh' and thought I wanted service dept. Surely AWSAM can chime into this!!
  • 1 year later...
Hey guys so after contacting the dealer that AWSAM got the update done at, I got the details on the update. He said to tell your local dealer to Contact Nissan Australia tech line department and refer to IQ contact 890008
so I did this and went in today to get the update applied to my car (2007 V36 sedan) and it turns out they couldn't download the update to my car for some unknown reason. So I don't know what the go is but I'm gonna give them a ring again tomorrow to follow up. I had a quick thought that maybe the update has already been done on my car in the last before buying it but then I thought it couldn't have because otherwise I would'nt be having the stupid bucking/stuttering and hard shifts that I get in my car... ?
Edited by moleman_1
  • 1 month later...
so I did this and went in today to get the update applied to my car (2007 V36 sedan) and it turns out they couldn't download the update to my car for some unknown reason. So I don't know what the go is but I'm gonna give them a ring again tomorrow to follow up. I had a quick thought that maybe the update has already been done on my car in the last before buying it but then I thought it couldn't have because otherwise I would'nt be having the stupid bucking/stuttering and hard shifts that I get in my car... [emoji20]
Let us know how you go, I'm having the same issues with hard shifts.
 Share
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime. The boost signal has to pass through the MAC valve from boost source (turbo outlet - effectively anywhere between the turbo outlet and the throttle body will do, but closer to the turbo outlet is best) to the wastegate. What you have done is connected it sort of like the stock solenoid. But it doesn't work the same way as the stock solenoid. That Tee piece that you have connected the solenoid to....? The solenoid itself serves that function. You should look up a typical MAC valve connection diagram for a single turbo internal wastegate application. You'll find one easily enough. Every single boost controller manufacturer that uses MAC valves will have one. Bugger it, I'll just grab the HP Academy one. The other thing you have to get right is that the boost source has to be connected to the correct port on the solenoid valve. This is because the solenoid makes the valve switch from connecting 2 of the ports when it is unpowered, to connecting one of those first 2 ports to the third port when it is powered. One inlet, two outlets. You will note from the diagram that the common port is port 3, the port to the wastegate is port 2, and port 1 is the vent (where the boost signal escapes when the solenoid pulses ON). As to the BOV.... the vacuum signal for the BOV simply has to come from the plenum. It must register boost when you're on boost and vacuum when the throttle is closed. That's all. The original location on the plenum is best. Best practice is never to interfere with the vacuum line running to the FPR. Just leave that one alone, as you will avoid causing unintended problems that might occur if you mess something up.
    • I was able to complete installation of the G4X ecu. I needed to reroute MAP vacuum signal from stock location to where BOV is connected on the intake plenum. Has anyone needed to do the same? When I connect vac port by the BOV flange to my HKS BOV, it doesnt work and I get flutter. I would to get BOV working, where would it be best to T in? Or would it best for me to move MAP vac line and T into FPR? Secondly, I installed a MAC 3 port boost solenoid and wanted to know if i routed it correctly. I place two lines from stock boost solenoid and placed it on ports 1 and 2, leaving 3 vented. The T for wastegate and boost source on compressor elbow is on port 2, and port 1 is connected to turbo inlet intake pipe. Please see attached pictures. Ill upload ecu config later today. Thanks in advance.
    • some people are still around weirdly enough - most people just use facebook now to ask the same 12 questions tho XD
    • Omg Rezz! Yep we're still here and actually seeing a trickle of oldies coming back.  How's things?
    • So I raised the car up a fair bit for shipping - see image - then lowered it again when it arrived. I then rushed to get an alignment in NL before the track and the shop just wasn’t anywhere near as precise as what I got in Japan. The guys that did the alignment this week said there was a fair amount of toe in the rear that could have contributed to the understeer. It was also the case that the rear camber went from about -2 to -3 at the shop in NL. However, since I’ve now got slightly wider tires in the rear - NS2Rs run wider than Accelera 651S - I could only get a minimum of -3 in the rear now due to clearance. Front is now -2.75 (-2.45 in minutes) due to being raised a bit (previously -3 in JP). So it’s likely a combination of the two factors, camber and toe. The issue now is I have more camber in the rear than the front and the next step on the front Cusco arms will put me at -3.5ish front which seems a bit excessive to me. The weird thing is I’ve never had any understeer at the track in Japan but they are very different circuits - Japanese circuits are much slower than the one I’ve been to here.    I’m probably going to have to start another thread for the E90. The plan is sort of to keep it as a daily but progressively mod it into a track car - honestly, you need a cage for the sort of speeds you go here. Just ordered the M3 front arms btw.  Love the car despite it being in pretty shitty condition. Oil analysis came back okay and it seems to have stopped consuming oil since fixing a load of engine bay things. Saw yours is a 335i right? f**king mistake on my part getting the DI N53 over the N52, fuel economy is insanely good though at 14-16 km/L.   Cheers, it’s great to see the benefits and pitfalls of different places. I’m contemplating going back to the U.K. around next year as the cost of living in the Netherlands is just ridiculous. GF is nagging me to settle and buy a house but I don’t know what LSD to buy.
