  • Replies 116
  • 3 weeks later...
the standard AFM sits inside the airbox, but u need the adapter from the AFM for your pod, if thats the one your talking about.
As for the pod, i know the K&N fits perfectly, not sure on others as i havent tried them , but if they are a similiar size they will fit in the box, as far as i know teh apexi one fits in with no problems .
if the hks is a mushroom pod, i think it may be to big to fit it.
NOTE: To anyone ive sold one to can u list your pod, as a refrence to others
Edited by mr_crust
Yeah the HKS one is a mushroom pod, it bolts on directly to the AFM. So if the AFM sits inside the shield then the pod would sit in there as well... providing the HKS one fits in the first place. Might just convince me to get that Apexi one! :teehee:
  • 1 month later...
Received mine today, putting it in tonight. I also grabbed 2meters of rubber edging for like $6 and edged any part that may come in contact with the paint. I'm also putting in heat shield foam on the inside. Good quality product and great value considering what others are charging.
Looks good Dan, and i might actually put that foam stuff in my own box and see how it goes.
Xizor: Ive got a few more made up in my spare time, but never really re-advertised them, but for anyone intrested i still have a few
  • 4 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
