Well I have looked using the Search button but cant seem to find what im looking for.
I have Just installed a new turbo onto my car but it seemed to do this on the old turbo.
I am boosting 1Bar and I could drive hard and then all of a Sudden it will just stop and it hurts your head when it does :D
another thing is when im boosting sometimes it seems to struggle, A friend of mine said when he was following me it had some sort of whiteish smoke comming out of the back when it was doing it.
Also where is the oil sencer placed as my gauge is playing up.
https://www.sau.com.au/forums/topic/100193-a-issue/
Put it back on standard boost and it won't do that.
Its the way the standard ecu is mapped. So that when the ecu measures more air flow then standard you go onto a higher load point that is mapped with lots of fuel and no ignitition timing.
Only real way around it is to go buy a PowerFC if you want more then standard boost.
The oil pressure sender is on the oil-water cooler behind the oil filter on the engine block. It has a yellow plug on it generally.
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1827170
this man is right on the money.
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1827265
the oil gauge playing up is common problem in the r32's.. I still never found out if it was the sender or the gauge itself, but don't freak if it says you have zero oil pressure.
Still gives me the $H!ts though!
as for the boost, 1 bar is roughly 14.5 psi. The computer wont like it, the intercooler probably wont, and neither will the engine. 12 psi should be a more appropriate figure.
and as stated above, an ecu upgrade should be a priority.
I also suggest a front/dump, high flow cat, and an intercooler.
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1827646
Well I guess I will have to get a Power FC then
and intercooler isnt a biggy yet. Big loads of power isnt what im after anyway, i just want to to run right.
Well everything seems to be fine at 14.5PSI
The engine is more then able to take that.
I guess I need to save up hard to get that power FC and see how she goes then
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1827826
dude! I'd be getting a FMIC before anything.... The standard intercooler is definately not able to cope with 14.5psi!
Get a FMIC, but not a huge 600x300x75 one... Get like a second hand GTR one or something.
Will work out perfect.
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1828389
hope this helps:
ChinaCopy Cooler 300x600x76 = $250
Piping = $600
Nismo FuelPump = $300-$400
Nismo Injectors 450cc = $600-$700
Nismo FRP = $160
PFC = $1000 + $400 to $450 for tuning or Hyperdrive will retune your stock ecu with a lumpy rom for around $800
maybe a clutch too $800-$900
ohh and how are you controlling boost?
ohh yes and your getting fuel-cut from ur ecu as everyone has said :P
question for you do you know what ur hybird turbo is rated at? as i would be interested to know if ur pushing around the 230-250rwhp without a fmic and if its pinging
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1830216
Well I have fixed some of my Probs my Bov was too loose and now she seems to be heaps better, just every now and then I get some fuel cut but she lets loose again and fine. But when I back off she still is over fueling I guess thats where a tune will come in handy
The Turbo is rated at 500+HP and 25PSI+
I ant pushing those limits I have no reason too.
https://www.sau.com.au/forums/topic/100193-a-issue/#findComment-1832982
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
