You will need a new/ chopped down tailshaft, new clutch slave cyl, and probably be a good idea to get a new cluch and your fly wheel cleaned up etc, and you need to work out the speedo-drive.
Done it, its nice. LOTS of peace of mind.
  • 4 weeks later...
Okey dokey, does anyone know what to do with the speedo drive? I've done the conversion but the only thing that has me stumped is this last trick.
The R33 uses a pulse sensor and the R32 uses a cable.
The BIG question is, is there a cable sensor that fits the R33 gearbox that can be used in the R32??
Any help would be appreciated
Ok I've had it done.
Transtunnel is fine. Dont need to touch it.
Obviously clutch, fly wheel etc all the same.
You will need an R33 clutch slave, I got mine new from nissan for $88.00.
Yes you need the R33 yoke, then you need the cef tailshaft, the idea would be to shorten this. However if your center bearing is stuffed like mine, then you might want to look at getting a 1 peice shaft as this is cheaper than replacing the center bearing apparently (lighter also, so you get back some of that extra weight of the gearbox + less rotating mass)
Rb20 cross member is fine, we just moved mine and put some spacers in. You might need an engineer to look at this to make sure its legal. Mine is actually mod plated.
The speedo... You need your red gear off the R33 speedo sender (the one that goes in the gearbox) this then needs to be attached to a navara speedo drive (32702 - 02G17 pinnion assembly), should be about $22-25 new from nissan, this then connects up to your speedo cable like normal. Just test it tho, should be pretty accurate.
Get some of the seals replaced on the box if they need it. You REALLY dont want oil leaking on to your clutch.
Get your fly wheel/pressure plate/clutch all checked out while the box is out. I had to replace mine that was a cost I didnt allow for.
And why does the gear selector matter? Wouldnt your RB25 box come with one? I dont belive we used my RB20 one.
But yeah, once its done your more afraid your crank is going to snap in your poor little rb20 than your gearbox
Quoting myself is bad :P
Just adding to that you need an S1 gearbox, as the S2s use a different clutch type. Cant remember which way it goes tho.
Hope that helps!
just to jump in here, can someone tell me what the difference between the boxes ratios are , specificly how much taller is the first gear? , i find first on my box to be useless for sedate driving and whatnot, gives me the shits revving to 80thousand rpm
Edited by Jolinator
SK did a whole thing up a while ago. I belive the biggest difference might have been 2kmh? Say 1st gear 50kmh rb20 box, 1st gear 52kmh rb25 box. Its seriously bugger all nothing. Dont worry about it. I didnt knotice squat difference.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
