ForSale: Perth
Tomei Poncams for RB25DET Series 2 R33 or R34 - $820
HKS 1.2mm Stopper type head gasket RB25DET - $430
Stainless Steel low mount manifold RB25DET -$400
PM me if anyone interested.
All stuff is new
Cheers
Neo
Can i get some photos of the manifold? and is it a chinacopy?
interested in some details on the manifold as well
a pic would be great
what grade SS is it made off?
who made it?
Does it mount the turbo in stock location?
how long has it been used?
cheers
  • 1 month later...
Hi mate,
If the head gasket is brand new and still for sale, id be happy to take it off your hands. Please let me know if its been sold, if not im in QLD if thats not to much trouble.
Thanks
Ptath
Not trying to annoy you or anything but the series 2 R33 RB25 head and the NEO RB25 head are vastly different. The former having hydraulic lifters and the latter solid for example.
The cams should fit one OR the other, not both.
I'm pretty sure you have the R33 series 2 RB25 cams there mate because the R34 ones are either 252 or 260 degrees in duration but yours are 256. Lift is different too.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
