god damn ... my poor n/a gts ....
everybody is ok ....
corner wasnt marked ..hit a guard rail at around 30odd km/hr head on ..well ...maybe at a 20 degree angle... front of car looks pretty rooted ...she still runs, i drove her out of the middle of the road...
from what i saw it needs:
radiator
front bar
binker set
headlights
bonnet
front d/s quater panel
new tyres
suspension work
steering arm was pretty skrewed too.
front drivers side wheel was up against the firewall..
have i missed anything?
prob stuffed up sumthin else on the inside...but thats bout it
The towie told me it would be upwards of 12gs to get it fixed (this is him quoting in the dark from what he saw..anybody want to price it up for me from the above information?)
Its insured for $14000 with justcar .... just wondering if that sounds like a writeoff or not? ...id really like to keep it.
Has anybody had similar experiences? if so would you care to share?
Just when i was going to get engine work and new shoes for her...ugh .... oh yeah..i wont be able to pay for anything till i get my credit card back too ...figured out i lost it yesterday because my wallets falling apart ..
maybe its a sign telling me not to have anything done to the car...?? ...maybe its a sign telling me im not supposed to have it? ...
ARRRGH!!!,......y do u feel so shit after accidents!
https://www.sau.com.au/forums/topic/100517-smashed-ma-car/
good to hear your ok dude.
i doubt it'd be a write off but you could probably get a panel beater to over price the parts and panels (go somewhere thats notoriously expensive like queen st. smash)
if you're handy with tools you could probably repair it yourself. so get a quote, get them to write you a cheque, and then dont go back to the place, just buy the parts and do it yourself. you'll make a fair amount of $$.
but you wont have any kind of warranty if you decide to do that.
https://www.sau.com.au/forums/topic/100517-smashed-ma-car/#findComment-1833372
it doesnt look to bad, it wouldnt be a write off, but seeing they go by new parts and its only insured for 14k then it may be a problem. just go to the wreckers source second hand parts, i saw someone on the forums in the for sale section is selling a series 2 front end in white, that is you SOLUTION!!
dave.....
https://www.sau.com.au/forums/topic/100517-smashed-ma-car/#findComment-1834295
Thanks guys...
Its going to chipping norton tomorrow now to be assessed.
I think theyre called allstate repairs or sumthing?
Thanks for the heads up MR R33. Wonder if theyll fit second hand parts I purchase?
Can anybody reccomend a reparier?
https://www.sau.com.au/forums/topic/100517-smashed-ma-car/#findComment-1835064
Your insurer will either repair the car or write it off . If they write it off they will pay you the sum insured ( if its agreed value ) less any excess.
If they deside to repair it they will pay the repairer NOT you .
If they deside to write it off you can make them an offer to buy it or go to the auction and bid on it , if you are the highest bidder its yours .
https://www.sau.com.au/forums/topic/100517-smashed-ma-car/#findComment-1835307
I dont believe this!? ...
i get a call from the peoples looking after my car and they recieved 2 quotes.
1 quote from some guy in punchbowl for $20k to fix the car
and the other from bankstown for $9800 ....
HOW THE HELL IS THERE A $10000 DIFFERENCE IN THE QUOTES!? ...
what am i going to get for $20k? ...a 2.6 DETT!? WTF?
https://www.sau.com.au/forums/topic/100517-smashed-ma-car/#findComment-1856920
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
