  • Replies 71
Posted Images
R32 = Hotcakes
R33 = Rolling tumbleweed
Probably due to the fact r33s are so common and now you can get compliance for $1200 the market is flooded.
We don’t like to touch 33s for this reason unless it’s a nice colour, manual and overall in very good condition
On the other hand the 32s looks like people can’t get enough. We still get calls for 32s that we sold a month prior.
And it is this reason you can buy a 33gtst for 14k and cheaper and 32 gtst for about the same price.
$1200 compliance? wtf?
Yep, there is something like 80+ workshops doing 33s at the moment. So add another $300 for tyres and you have a full compliance.
Edited by Mecha
Sorry I don’t know all my 33 info off by heart, we don’t do that many of them (we do mainly euro stuff).
But the $1200 price is a definate.
True but I think you may need a separate certificate to comply them.
You nee a separate certificate for 2 door, 4 door, gtr etc except for non turbos which can be brought it.
roflafagus... $1200 for R33 compliance... $1200 for a 15 year old R32 maybe. And wtf different price for S1 and S2... that's a new one. You don't do many of them, yet you charge half the going price anywhere in Australia? That dosen't add up.
I'd like some concrete evidence of this to believe it, and if its true then this compliancer will be getting a shit load of work.
OK,
Well I got some more info; compliance doesn’t matter if it’s S1 or S2.
We can DEFINATLY get it done for $2200 + tires so even in this case it can be done cheaper.
And I have been told from a VERY reliable sources that it can now be done for $1250 (not $1200 like I previously said) + tires, but I guess this price is not 100% confirmed as we have not had the chance to bring in a 33 and get it complied there.
Either way if someone was to import a 33 through us we would defiantly follow this $1250 price up. Worst case scenario you can get it done for $2200.
Still a saving.
So how much would it cost to get a 1998 R33 Series 2 GTS25t though you guys from start to finish?
lol, im not offended, i just think its stupid to say that they are the least desireable, and everyone has them, in the same sentence no less..
Maybe he means less desireable in terms of looks?
Most people don't necessarily buy R33s because they think they look better, you'll find most people like the look of R32s and R34s. But when talking about the GTST/GT-T market, its hard to go past the R33. Unlike the R32, its RB25 equiped, more spacious also its almost as good as an R34 and much cheaper. So the most pracitcal/cost efficient choice becomes the R33, hence their popularity.
Also compliance for $2200 is cheap. I had my old 33 done for $2500 w/o tyres, about a year ago.....the workshop wouldn't do R34s by any chance Mecha? I'm thinking about importing one soon....
Also $1250? wow. that would be cheap, but i don't think it can be done, 15yo compliance is at least 1000 bux these days.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
