my baby was just in an accident a few days ago, long story but i'll make it short......
it was his fault cops told me and also he has no insurance :D so im gonna show how get the money from him to repair my car...!
anyways since i have to fix the front of my car i was planning to change it and make it look like a GTR meaning gtr bonnet and gtr front bumper..... i heard from some ppl that the orginal gtr bonnet and bumper doesn't fit on a gtst is that TRUE????????????????
and also where can i get the cheaps part for my car?????????????? eg.. front bumper and gtr bonnet (oem version) not fiberglass....
need your help thanx
cheers flukey.........
https://www.sau.com.au/forums/topic/100826-need-help-please/
get a normal GTST bonnet and grind the nose (and get a Nismo nose clip) that way the latch will still work fine and you can fir the GTR grill
Your joking right? What a stupid suggestion
Flukey: Get an R32 GTR bonnet, grill and GTR bonnet latch.
Try Just Jap at Kirrawee they should be able to assist
everything should go straight on, if you changing the gaurds you will need GTR blinkers, and the bonnet will need the GTR latch as mentioned.
you can also modify the existing latch to fit
Hey guys for those of us silly people, When you change to the gtr front bar do you have to change over to the grill as well?
I recently did the this conversion on my GTST and it all bolted on fine just needed to slightly modify the bonnet release. And I have seen in some cases where they have to cut a small piece out from the underside of one of the fins so that the GTST bonnet latch has room to move. Other then that it all just bolts straight on! :D
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
