Hey ppls.
I got EPA’d again.
Performance Exhaust in Ringwood recommended replacing my Cannon at the back with a Magnaflow box.
Reckons with no other mufflers, this will make the car legal.
Anyone had any experience with Magnaflow?
Sound good?
https://www.sau.com.au/forums/topic/100843-magnaflow-mufflers/
  • Replies 65
hay bass they are not bad we (my dad and me got one made up for just for epa stuff) they are great and sound ok but just get a flang puton behind the cannon and get a stock muffler and bolt it on and then get it tested and when you get home change it over again.
I'll be putting in a flange so that when racing I can put the old muffler on just for aural pleasure.
I'll leave the Magnaflow on all the time, cos it's too loud in the car at the moment.
I HAD a stock exhaust and I lent it to HasLo on these forums.
It has since been fitted to his car for complience and then lent to one of his friends workshops who backed over it with a forklift, so I have no exhaust.
I want to reduce the noise of my car anyway, so the new muffler is the go.
...driving around in James' brothers WRX which has a Magnaflow cannon, it is still damn noisy for a stock car with stock exhaust apart from the muffler. Dotn know what model muffler it was...but i supose if you get one of their quiet exhausts rather then a 'performance' exhaust ????
Oh, and it's got a slightly offset muffler (Fujitsubo) in the middle
It's got a muffler in the middle AND one at the rear and it's still too loud. Damn they must not be much of a muffler.
What we do is fit a bolt in restrictor in the rear muffler, then it is a simple matter of undoing 4 screws and removing the restrictor. The restrictor is a reverse cone shape and makes the exhaust bounce outwards into the silencing material, rather than go straight through. With your access you should be able to make one up out of stainless steel pretty easily.
You trim the size of the hole in the restrictor until you get the desired noise level. Start of quite and gradually trim until it is at the limit. It does knock the top off the performance, but it is quick and easy to remove.
:P cheers :P
damn , i just fit a trust power extreme II about 3 weeks ago
theres a r33 power getter but no 34 so I guess its that . did you have to modify anything to get it to fit ? i had to mod my peII for the 4 door and that was a r34 exhaust anyway
strange that its loud , fuji are one of the quieter exhaust manufacturers around and my s15 power getter had no problems passing the pits .
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
